Question about Delstar DS 31024 MP3 Player
Hiiiiiiiiiiiiiiii REMOVABLE DISK hI AM HAVIN A PRO WIT MA FLASH DISK(USB) I MEAN IT DOESNT WORK
  • 26 Answers
Hi
Try it on any other PC. if other usb devices work with your PC you may have dirty contacts of your USB.
Posted on Aug 29, 2008
I didn't find a port in ma laptop in which i can plug n play b'coz it didn't plug in into usb ports
These are the minimum system requirements of the flash drive you bought.
• Computer with a USB port • Latest version of Windows XP, Windows Vista® , Windows 7 • Mac® OS X 10.4, 10.5, 10.6 • Minimum free disk space: 600MB recommended
Any way back to the question, there is a protective plastic clip for the gold contacts have you tried removing it before using, it might be the reason you cant stick it to any USB port. Any way don't lost the cap so it can lessen dirt on the gold contacts.
Hopefully this information helps.
Thank you for using FixYa.
Aug 15, 2011 | LaCie CooKey USB flash drive - 16 GB USB...
My memory stick pro-hg duo just stopped working all of a sudden for no apparent reason, it can't be recognized by any of the devices i have that support it, is there a way i can repair it
Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
If this doesn't work then it is faulty.
Dec 21, 2009 | Sony Electronics - Others
Want to format sd card wit fat (fat12)can use vista windows 7 or xp. do you know of a program?
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Nov 21, 2009 | Transcend (589307) Media
I have a Toshiba HDD2190 C DC +5V 0.7A 40 GB Laptop harddisk which when I plugged into USB drive (by using a USB cable), WIndows XP Profesional detect it but I can't find it's Partitions in my computer. In...
In general, you need to install the correct drivers for the enclosure, not for the hard disk. Seeing as you have XP Pro, this is probably unnecessary though.
Also, 0.7A is 700 mA, and this exceeds the USB port maximum current which is 500 mA.
Most (not all!) laptop drives will run even if under a slight undercurrent, but this depends on USB port electronics and enclosure electronics.
Chances are that you won't be able to run the disk unless you plug it into an externally powered USB hub supplying at least 750 mA per port. The 100-500 mA supplied by your PC's USB port is enough to power the enclosure electronics and the host controller, but not enough to get the HD to spin properly. As a result, the HD can not be initialised and the enclosure will report an error.
Some hard disk enclosures come with a "USB Y Cable" or "double power cable" which joins two USB ports to get double the current, and can support HD up to 1.0A. If your enclosure comes with one of them, try that first.
Nov 02, 2009 | Toshiba (HDD2190-50PK) 30 GB Hard Drive
My USB flashdrive cannot be opened
have you tried it on a different usb port? if that doesnt work you may also try it on a computer
Jul 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My flash drive says I am using data when I am not
i mean when i insert my flash disk in to the computer and then try to open it displays format disk
May 01, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Maxtor OneTouch III Mini not appearing on MacBook Pro
Hi Lois,
If your Maxtor appears in Disk Utility but the disk volume is not displayed, it's possible that the partition on the disk has been deleted for some reason. If that's the case, you will have to use a disk partitioning utility to create a new partition and then format the hard drive.
Best wishes,
Graemevm
Apr 28, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Delstar DS 31024 MP3 Player Logo
37 people viewed this question
Top Delstar Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
