Question about Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47
O S RELAY
WIRING DETAIL OF DFC1 O S RELAY
Freezer wiring diagram
A "potential" relay is a voltage controlled start component for the compressor. If your sure the potential relay is bad, not the start capacitor or a seized compressor, Order one from G.E. and replace it.
Dec 07, 2013 | GE Freezers
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
Apr 06, 2013 | True T-23F 23 Cu. Ft. 1 Door Freezer
I have summit commercial freezer with embraco emi 60her when turn the power on, fan start run then compressor start run about 30 second the trip the compressor. ans i can not see any run or start...
The start relay should be on the side of the compressor and attached to the three prongs that wiring attaches to on the compressor.Is the problem causing the breaker to trip in the circuit breaker box? Sea Breeze
You can have someone match the start relay and the run capacitor at a refrigeration supply store near you or you can contact Summit
HERE
http://summitappliance.com/support
Apr 02, 2013 | Freezers
It won't start no click sound if I turn the temperature control to maximum
If your hearing a clicking sound and it won't start your looking at either the relay switch for your compressor or the compressor itself. I recommand replacing the relay switch first to see if that solves your problem. Just look for the model number of your freezer, visit your local part store (reliable, amre) and ask them for the relay switch for the compressor. It should be under 20 bucks or so.
To install the part you first need to located the compressor. There should be an opening to the freezer somewhere in the bottom. Once you find the opening (after removing the cover) you should see a large cylinder metal container, this is your compressor. If the freezer unplugged located a small box attached to the compressor that looks similar to the relay you purchased from the part store. Remove the wiring for the old relay and then proceed to remove the relay (it should just be plugged in). Once it is removed place in the new relay. Plug back the fridge and see if your freezer works. If the problem persists it will be your compressor. You should have a professional have this replaced as it requires weilding and removal of the freon gas. The repair for a compressor job is $500 up.
I hope this helps and good luck. Please give positive feedback if this helps :)
James Memije
Head Technician
Accufix Appliance Service Centre
www.accufixappliance.com
Nov 20, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
What rewiring is needed to replace the overload relay with a universal kit, on an upright freezer? Kelvinator model VA16 W. There are two relays that connect to the compressor that need to be replaced....
The two pieces are Relay and Overload.
If you are using a supco relay/overload combination that has three wires with terminals and two wires with stripped ends the wiring is as such.
Red-Run Terminal, White-Start Terminal, Black-Common Terminal (Overload was wired to this)
Stripped wires are connected to line cord along with condenser fan wires.
Nov 19, 2010 | Frigidaire Freezers
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Maytag Freezer quit working, Light is on, but not cold. Is there anything I can check before calling a service center. The model is MQU2057AEW.
According to your wiring diagram this is about the simplest machine in the world to work on. a369c99.gifMounted on your compressor is a relay. The relay allows all the copper windings in the compressor to be energized momentarily to get the motor in the compressor started, then it drops half the cooper out because that's all that is needed once it is up and running. A thermostat allows current in the circuit till the desired temp is reached. I would check that relay first for signs of wear. They go bad with age. 46684ba.jpg743f4b2.jpgIf the relay is good bypass the thermostat's to see if she comes to life. If she starts working replace the thermostat.
Jul 09, 2010 | Maytag Freezers
Need wiring diagram for GE model CA15DRN upright freezer-compressor relay busted & not sure which wires go to which terminal on compressor.
http://genet.geappliances.com/DocSearch/pdf/49-6545.PDF
The best I could come up with is this site for the user manual. Not able to find wiring diagram on this GE site. Hope this helps ya.
Nov 24, 2009 | Freezers
Chest Freezer Wiring
hi mel,
green with yellow are ground wires and usually are from compressor to system chassis from your 3 prong plug use the green wire and just find a point on the chassis to pin to if you can get model number you can find on kenmore website
May 01, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
96 people viewed this question
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
