Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
running slower than normal, or a program is not performing properly. A
soft reset is also necessary after the installation of some programs.
If a soft reset is performed when programs are running, unsaved work
will be lost.
To perform a soft reset:
o Use the stylus
to lightly press and hold the RESET button on the bottom of your
device. The device restarts, and then displays the Today screen.
Warning! Always turn off your device before performing a soft reset or installing/replacing the battery.You
can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its
default settings-the way it was when you first purchased it and turned
it on. Any programs you installed, data you entered, and settings you
customized on the device will be lost. Only Windows Mobile software and
other pre-installed programs will remain
To perform a hard reset:
Press
and hold both soft keys on the device. Keep these keys pressed, and at
the same time, use the stylus to lightly press and hold the RESET
button on the bottom of your device.
Release the
stylus but keep the soft keys pressed when you see the following
message on your device screen. "Do you want to erase all user data and
restore to manufacture default?" will appear.
Slide open the hardware keyboard, and press R to restore to factory default or press X to exit the hard reset process.
Hope this helps, let me know if I can help you with anything else.
JimmyC
