No sound i am not getting any sound when i install the driver for my GA-7n400 board. i think i have the right driver. how can i tell if it is the right driver and how can i solve this problem?
  • ncube109 Aug 29, 2008
    no sound divice in my toshiba l70
  • Anonymous Aug 29, 2008
    device manager
J'ai acheté mon pc avec le système d'exploitation vista installé. après avoir désinstallé vista je n'ai plus de son lorsque je lis mes fichiers audio et vidéo.
Posted on Aug 30, 2008
Do gigabyte motherboards GA-7N400 pro2/GA-7N400/GA-7N400L support usb3 cards
Yes, but please make sure you buy the PCI interface version, some of available USB 3.0 card in the market are mostly PCI-express interface. Just tell the store you will install it on the old PCI slot (white one). You also ask them if they have issue with the card that they recommending to you.
Nov 04, 2011 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
GA-7N400 Pro2 at startup i hawe long separate continus beeps
Possibly Ram, try and see if removing and replacing helps
Other causes may be voltage issues ( check the bios and see what the various rails are telling you)
eg: there should be readings for 12 volts 5 volts and 3 volts, if any are + or - by 10%, there is an issue with the voltge controller. You might want to try a replacement PSU?
After this.. bad video ( check by installing a video card)
Temperature warnings ( check in bios to see under PC health status) what the cpu and board temps are running at, if above 70 degrees...overheating issue or more likely at start up, board thinks that the CPU fan is not running fast enough or not working. If fan IS working, you have a problem with the CPU fan sensor, will need to replace mobo
Jan 27, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
Looking to upgrade my ram on on ga 7n400 pro mother board and was wondering what is the best to get?
see a professional or read the manual for your motherboard because every motherboard has its maximum capabillities
Sep 26, 2010 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
GA-7N400 Pro2 - GIGA-BYTE i need motherboard driver
can you try this link below:<br /><br /><a href=""><br /></a><br />hope that was helpfull<br /><br />
Aug 30, 2010 | Gigabyte GA-7N400 Pro2 Motherboard
Final video card upgrade for "GA-7n400 Pro"
Thank you for your query
Looking at the specification of the motherboard, the maximum you are looking at is 512MB AGP card (Nvidia or the like), unfortunatley i cannot tell you exactly which one, as differnt cards are used for different things i.e. gaming, web creation etc etc
Feb 12, 2010 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
No video and no posting
Your GA-7N400 PRO2 motherboard does not have a built-in video graphics card. You need to install an AGP 8x graphics card into the AGP slot on the motherboard. When you removed the heat-sink & fan assembly the CPU starts to over heat & the CPU will shut down the system. That's why you heard the, european ambulance sound.
If it wouldn’t, you would fry the CPU. Make sure you add thermal grease on to the CPU before re-assembling the heat-sink & fan. Don't forget to plug the CPU fan power connector on to the board.
Motherboard specs;
Download & read your manual. Open the link provided here;
Aug 12, 2009 | Albatron PX865PE Pro Motherboard
On board sound
Hi nrls14, it can get pretty confusing with Gigabyte.
Go to page 9 in your manual or Pg 13 if using Adobe Reader. Motherboard layout. If you download the manual which is in pdf format you'll be able to enlarge the manual which will help you to see everything much better.
Download manual from here:
This is the English manual. (Downloading from china is a faster site).
Find SUR_CEN located between PCI slots 2 & 3 on the motherboard. Than go to pg 32 in manual or pg 36 in pdf. Set the pins SUR_CEN. Set a jumper over pins 1&2 & 5&6.
Front Audio Connector, leave a jumper across pin 5&6 & 9&10 (Default). On page 22 in manual, pg 26 pdf. Follow Method1:
Instructions. (Test your speaker system). You may need some tweaking & this can be done with the software included on the Gigabyte CD by installing the sound effects manager. Go to page 78 in your manual or pg 82 in pdf. Page 80 in manual, pg 84 in pdf. For six channel 5.1 sound. If you decide to use the Advanced 6 Channel Analog Audio Output Mode (using Audio Combo Kit, Optional Device). Follow the instructions on page 81 in manual or pg 85 in pdf. (Do not let the picture on pg 81 spook you). Pg 81 shows a set of pins not located in-between the two PCI slots. You make this connection by removing the two jumpers on SUR_CEN & plug in the SURROUND-KIT on to SUR_CEN pins. Lastly, both motherboard manuals are the same for the GA-7N400 & the GA-7N400 Pro.
Good luck nrls14!
Aug 25, 2008 | Gigabyte GA-7N400 Pro Motherboard
clear your bios setup with jumper settings.
take your cmos cell 15 minutes then put in position.
also check smps.
power cable,power supply.
Mar 26, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Audio driver
The GA-7N400 Pro 2 uses the Realtek ALC650/655 Audio AC'97 Codec for onboard sound.
Here is the site you'll need to go to.
I would recommend that you be sure to install ALL of the basic drivers. This includes not only the audio drivers but the CHIPSET drivers as well. Especially since this is an nForce 2 board. Those boards are rather touchy. Chipset drivers will keep the system more stable and help it to run more efficiently.
You may also download more up-to-date drivers for the audio from RealTek's website at:
This should be easy... :)
Nov 04, 2007 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Where to find manuals & Drivers
Here is the link for the drivers, bios, manuals, etc of this motherboard.
Good luck
Nov 01, 2007 | Gigabyte GA-7N400 Pro2 Motherboard
Computers & Internet Logo
David Payne
David Payne
