Question about Acer Aspire 3690-2196 Notebook
Shutting down I cannot shut down my laptop properly it has only started to do this a couple of days ago but when i click on start then shut down it shuts down as normal but then the light at the front of the laptop is still on indicating that the laptop has not shut down right so i have to hold down the turn on button until the light at the front goes off, but i do not like doing this as i am told it is unsafe for my laptop and that i should shut it down competly if anyone can help me with this problem i will really appricate it. Thanks alot xxx
    President:
  • 2,961 Answers
What is happening is it is hibernating not shutting down, open up acer empowering technology and go to the power settings or click on the battery icon in taskbar and click power options, then there will be instructions that say when i turn off; power off and not hibernate as probably selected.
Posted on Aug 29, 2008
Samsung Laptop Shuts Down Unexpectedly
CHECK THE FANS! The biggest enemy to your laptop is HEAT! You just replaced the display it's very possible you inadvertently disconnected the cooling fan. Clean it while you have it apart dirt and dust prevent proper cooling
Jun 28, 2017 | Samsung Computers & Internet
My 1995 BUICK PARK AVENUE cranks up, and drives fine. when I go to slow down it just shuts off on me. It started a couple months ago, but only happened once or twice. A couple days ago it did it 7...
Have someone take the mass air flow sensor off and clean it with a non-chrlonated brake cleaner.Make sure its dry before reinstalled and do not touch wire inside sensor with your fingers the oil from your fingers can damage it.
Apr 21, 2011 | 1995 Buick Park Avenue
Laptop shut down error
The DDR2 RAM memory has failed and must be replaced.
You can get a new one from here
http://www.edgetechcorp.com/memory/upgrade.asp?cid=28784
Jul 09, 2010 | Dell Latitude D410 Notebook
Is simply shutting the notebook a safe way to
The proper way to shut down a computer is to click on START - Turn off Computer - then click Turn Off.
Sep 28, 2009 | Toshiba Satellite A105 Notebook
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Laptop locks up during shut down
fist of the click the start and click the run and type the recent and click.......ok and remove the all file in new windows
second method click the start and click the run and type the chkdsk and click.......ok
thard method click the start and click the run and type the temp and click.......ok remove the all file in new windows
Apr 01, 2009 | Dell Inspiron 1501 Laptop
Laptop monitor shutting off after after a few minutes
I have exactly the same problem though I have a toshiba laptop, after 3 years of intensive use i think the lcd is gone, cos it has nothing to do with os as it did the same even when entering setup. btw i used to let it 247 on like you did !
Jan 01, 2009 | Dell Latitude D600 Notebook
Car won't start
test/replace the alternator.also be sure all connections are tight at battery...ground side other end of battery especially..good luck
Dec 12, 2008 | 2003 Kia Rio
Acer Aspire 3690-2196 Notebook Logo
221 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
