Question about Amana Washing Machines
Reset or replace motor overload protector in clothes washer, model no. CW8403W.
Moter overload but all electrical connection ok. how to solve this problem
Posted on Mar 06, 2009
Thermal overload protector
Use the first part of the model number to fid who the manufacture of the saw/ motor is. Example: 110.123456- 110 is Whilpool. Then cal the manufacture direct. Also sometimes Grainger has direct replacements.
Jan 25, 2014 | Craftsman Sears 10" Table Saw Motor 62505
Where can I find a replace thermal overload protector?
http://www.mypool.com/Products/Catalog/mo.asp for the capacitor.
See if there is another part number for that breaker (CET51 ABM).
Feb 28, 2009 | A.O. Smith SQ1102 Pool Pump Motor
I have a Kenmore Elite Calypso It Displayed C1 then blacked out
Instantaneous Current ("CI") spike. Overloaded washer or a problem with the motor windings (drive motor, not pump motor, thermal protector or motor controller. Wash less articles next time. If the problem does not recur, overloaded washer might have been the problem. If it continues to occur, might need a service call unless you like to do it yourself (get a service manual - google the model #).
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Model# LW6163WM/LM washing machine
Dear usaguitarman Welcome to fixya.com
I'm Huuum and happy to assist you,
You said, washer fills with water. then the motor overload protector starts clicking
in and out.and there is a burning smell. I am able to spin the water back out.
The belt needs to be replaced but I don't know if that could cause my problem.
Yes I believe the belt could be the problem!
That is more than likely the burning smell!
Change to belt.!
While your at it, unplug the machine for 5 minutes or more and then it will reset the system too!
Let me know how wonderful it performs after these repairs!!!!!!!!!!!!!
i believe you will be fine!
Bless You,
Huuum
Please do not forget to enter a rating when you are done.
Thank you
Sep 23, 2008 | Amana 3.2 cu. ft. Top-Load Washer
I have a ld850sa03 washing machine that only agitates in one direction maybe gearbox failure,if so where do i get one,can you help
hi In most cases, motor malfunctions should be handled by a professional; do not try to fix the motor yourself. If the motor is a universal motor, however, you can change worn carbon brushes when sparking occurs, as detailed in the how to repair appliances article. To save the expense of a service call, remove the motor from the washer and take it to a professional service person, then reinstall the repaired or new motor yourself. To access the motor, remove the back panel of the washer. The motor is mounted on an adjustable bracket.
There is one other motor problem you can repair yourself. Washer motors usually have an overload protector clipped to the motor. When this component fails, the motor won't work. Before you take the motor in for service, test the protector with a VOM set to the RX1 scale. Disconnect one electrical lead wire to the protector and clip one probe of the VOM to each protector terminal. The meter should read zero. If the needle jumps higher, the protector is faulty and should be replaced. Pry up the protector with a screwdriver and replace it with a new one made specifically for the motor or washer. Connect the new protector the same way the old one was connected.it is not gear box.............
Sep 13, 2008 | Westinghouse Washing Machines
My LG front load washing machine WD-1016 is stuck shut what can I do
hi There is one r motor problem you can repair yourself. Washer motors usually have an overload protector clipped to the motor. When this component fails, the motor won't work. Before you take the motor in for service, test the protector with a VOM set to the RX1 scale. Disconnect one electrical lead wire to the protector and clip one probe of the VOM to each protector terminal. The meter should read zero. If the needle jumps higher, the protector is faulty and should be replaced. Pry up the protector with a screwdriver and replace it with a new one made specifically for the motor or washer. Connect the new protector the same way the old one was connected .
Sep 12, 2008 | LG Washing Machines
Hotpoint wma58
Could be a bad overload protector in the motor. Some machines have a circuit where the machine rapid advances to the end when the motor overload protector kicks in. This would also make sense that it started happening in the Spin cycle when the motor draws the highest voltage.
Feb 29, 2008 | Hotpoint WMA64 Front Load Washer
Kenmore calypso model 11022086100
Thermal overload protector is mounted on the motor. Normally the motor is replaced.
Jan 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore washer model # 110.24086200
The C1 code indicates the "instantaneous current limit" trip. This signifies problems with the drive motor, thermal protector, motor controller. Overloading the machine will cause high amps and trip the unit. Instantaneous current trip occurs if there is a current spike of 26 amps instantly at the motor windings in which the motor overload trips. check bearings for lubrication - or as stated above overloading the washer.
Sep 06, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
274 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
