Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9150PWO Whirlpool duet
Getting a DL f. Door will not unlock. I need to get the clothes out before they mildew. Called for service. They can not come out till Tuesday. How can I manually unlock the door?
    Problem Solver:
  • 6 Answers
Take bottom panel under door off there 3 screws you 'll need a star tool reach on the right hand side there is a yellowgreen strap pull it and door will come open
Posted on Aug 30, 2008
Door locked error code dL/F
If your door is already locked and you get an "F" error press and hold the cancel button, and select drain/spin. If this still doesn't work and your clothes are trapped inside do not resort to getting out the crow bar and a sledge hammer. (Though you may really feel like doing just that). You can manually unlock the door by following these steps:
- Unplug washer or disconnect power.
- Remove the lower kick panel.
- Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
- Located on the bottom of the door switch/lock unit is a teardrop shaped tab.
- Gently pull the tab down about a 1/4˝ or until a click is heard.
- The door may be now opened.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Check page 46 and 51 in tha manual given in the above link
May 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F DL
https://secured.whirlpool.com/Service/...nsf/.../Duet%20Job%20Aid.pdf
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
http://elektrotanya.com/whirlpool_ghw9100l,9200l.pdf/download.html
service manual above/
Apr 10, 2010 | Whirlpool GHW9100L Front Load Washer
Sud message on whirlpool duet front load washer also after washing clothes i notice a mildew smell on the clothes.
You areusing too much soap. Run a rinse cycle and use less soap next time. As for the mildew leave your door cracked open after you are done using the machine.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes/towels smell like mildew
Front load washers are so tight ( to seal in water ) that they tend to leave water in door gaskets and other places.. This water gets stagnant and can build up mildew etc..Home depot and other home goods stores sells a product called AFRESH and you use it about once a month ( with no clothes in washer).. It does help a bit..
Other techniques you can try would be to wipe down the gasket around the door opening after a wash is complete and to leave the door open between washes to let it air dry.. You should be using HE type laundry detergent and very little of it ( sveral drops is enough per load)..
hope that helps you...
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pwo code
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance.
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
231 people viewed this question
Dan Webster
Dan Webster
Sal De
