Question about Sanyo PLC-XT11 Multimedia Projector
Sanyo PLC-XT11 The projector has a new bulb, but I'm having a problem keeping it on. It will come on start up then turn itself back off. Any suggestions would be greatly appriciated..
I need mount
Posted on Oct 13, 2008
Sanyo plc xu115 new bulb wont fire. power light turns green at first but after a few seconds it turns flashing red. the old bulb exploded on this projector.
Could be a burnt capacitor on the circuit board. Replace capacitor if you can determine which one it is. There are only a few.
Apr 20, 2011 | Sanyo PLC-XU115 Projector
Sanyo PLC XT11 Device turns on, counts down from 30, and then turns off and uses fan on high in what appears to be a cool down cycle. The lights verify that the device thinks it is overheating. Lamp...
The air filters on projectors are very important.
You need to take them out and clean them regularly, if not projector can overheat.
Also check all the grill are not blocked, using a vacuum cleaner with a brush attachment on a gentle **** is the way to clean them off.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sanyo PLC-XT11 Multimedia Projector
How to find out lamphour in PLC-XT11
do the follwing setting on your projector to reset the lamp hour
1.Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button to move a red frame pointer to SETTING Menu icon
2 Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move
the pointer to [Yes] and then press SELECT button.
3.Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
Feb 02, 2011 | Sanyo PLC-XT11 Multimedia Projector
I have a model PLC-XT11 and when I turn the power on the temp light and green ready light begin to flash. The red lamp light is on steady. I replace the lamp but no luck.
one or more of the fans may not be working right. also, the temp sensor may be shot. if the last time you used it it wasn't shut down properly, it may still be in cool-down mode.
Nov 06, 2009 | Sanyo PLC-XT11 Multimedia Projector
Sanyo plc-xt10a will not power up. ready light is not on. power to unit is good.
First, check the lamp/lamp door--the door has a safety interlock that prevents power from getting to the projector. Make sure the power *is* getting to the unit by using a known-good power cord. Also, check the 3 air filters. If one or more was clogged with dust, the unit might have had a thermal sensor trip. There is also an internal fuse on the power supply which may have blown.When was the last time the projector worked correctly? Have there ever been any power problems related to that unit before? If the above checks yield no success, the projector will have to be repaired at a service facility. Hope I was of some help---Rick
Sep 09, 2009 | Sanyo (6103055602) Projector Lamp for...
I just replaced the lamp on my Sanyo PLC-XP55 projector and reset the lamp counter but now it won't turn on. When I press the power button, it goes into a cooling mode for 90 seconds and then never turns...
did you get the bulb from sanyo, or from another company that sells aftermarket bulbs? some of those are cheaply made and malfunction shortly after if they work at all. find your reciept, take it back and get a new one.
Jul 22, 2009 | Sanyo PLC-XP55 Multimedia Projector
Sanyo plc sw30 help
i had a sanyo plc sw30 wich had the same problem and it turned out to be the bulb replaced it with new one and this seemed to solve the problem. Theres a few places to get new ones but they are not cheap looking at between £150 to £180 hope this helps
Nov 02, 2008 | Sanyo PLC-SW30 Multimedia Projector
Lamp turns off when projector is upside down
check the lamp door switch or the lamp door for warping.
Jan 22, 2008 | Sanyo PLC-XT11 Multimedia Projector
Sanyo PLC-XT11 Multimedia Projector Logo
238 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
