Question about HP Officejet J5780 All-In-One InkJet Printer
How do I insert a new cartridge in the j5780
I have lost the instructions to take out and put in a new cartridge. How do I do this? At the moment I can't finout how to access the old cartridge even
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 29, 2008
Just got new catridge refilled and it only did two documents now says replace HP Office Jet J5780
Sounds like the refilled cartridge chip is not good, take back to where it was filled and get another cartridge
Feb 08, 2013 | HP Officejet J5780 All-In-One Printer
How do I clean the printer head on ly HP J5780 all in one
Hello thanks for using Fixya
In
HP Officejet J5780 All-In-One InkJet Printer cleaning the cartridge is not difficult, but it is important to use the appropriate technique. The things you need is "Cotton swabs" & "Distilled water"
Now follow this procedure
  • Open the front door of the printer, located below the scanner lid, by swinging it down. The print cartridges will move to a position where they can be accessed
  • Unplug the printer to prevent the cartridge dock from moving away from the center of the printer. Press an ink cartridge down until you feel a "click" then pull it out of the dock.
  • Dip a cotton swab in distilled water and use it to clean any built-up ink from the metal contacts on the ink cartridge and from the area around the ink nozzle. Avoid touching the nozzle itself, which is located in the center of the bottom of the cartridge. Discard the cotton swab if it becomes dirty, and use another to continue cleaning. Keep cleaning until the ink cartridge is no longer dirty, then set the ink cartridge aside.
  • Remove the second ink cartridge and repeat the cleaning process. Set both cartridges aside until they are completely dry
  • Replace an ink cartridge by holding it slightly below the dock, then pushing it up and in until it snaps into place. Do the same with the second cartridge. The black cartridge is inserted into the right slot on the dock, while the color cartridge is inserted into the left slot.
  • Close the front door of the printer, plug the printer back in, and turn it on.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 26, 2011 | HP Officejet J5780 All-In-One InkJet...
Replace ink cartridge
For replacing ink cartridge follow bellow steps:
  • Choose colors you want to insert cartridge.
  • Turn on your printer and switch should be at top right hand side.Open the printers lid.Wait a moment while cartridge carrier is being automatically disengage.
  • Put your hand behind the existing ink cartridge and pull it towards you until it pops out.Dispose old cartridge and reenter new one.
  • Now, your cartridge will working properly.
Oct 10, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I just changed my black cartridge and the printing
Dip the bottom of the cartridge in some hot water. This should open the head so the ink can flow out freely. Once the ink is flowing into the water remove and dry the whole cartridge. Insert into printer and print.
Good Luck
Jul 20, 2010 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 all in one Alignment problem cartridge will still not align after I've gone through the alignment routine. Cartridges are genuine HP and fairly new
Usually the yellow is the culprit. Dab the cartridge on a paper towel and see if all colors make a spot or line. if any color is missing it will not pass alignment, and you need a new cartridge.
Dec 30, 2009 | HP Officejet J5780 All-In-One InkJet...
I insert a new print cartridge and align it as asked. But the printer says it won't align. I have an HP officejet J5780 all in one. Thanks.
Several Steps to take.
If all else fails try a new or different cartridge before you get too carried away looking at the printer for the problem.
1. Turn off the printer and unplug it from the power source for approx. 30 seconds (some units take this long to bleed the power out of the unit).
2. Plug in the printer and step thru the start up procedure (turn it on what ever - not the set up program).
3. Retry the cartridge alignment procedure.
4. If alignment still fails verify that the cartridge electrical contacts are clean and the jet opening is not blocked.
5. Reinstall after cleaning and checking.
Aug 21, 2009 | HP Officejet J5780 All-In-One InkJet...
Dumb me cannot figure out how to get to the ink cartridge
No problem. You can access the instructions online. Go here and you'll see their complete instructions, and troubleshooting guide if you have errors you can't sort out.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 03, 2009 | Lexmark X75 All-In-One InkJet Printer
Replace ink cartidge
Here is a link to the Setup Guide. Go to Step 5 for instructions for ink cartridge installation.
J5780 Setup Guide
Dec 07, 2008 | HP Officejet J5780 All-In-One InkJet...
"Insert right cartridge" J5780
u better check the catridges first specially black catridge,or get it tested on any other printer,but before that wipe the back side circuit section of the catridge with a tissue paper,n try,if the catridge is ok then the catride unit is has to be replaced
thnx N
Jan 14, 2008 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
