Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
Mx 3000 universal lcd remote
I replaced the battery for mx 3000 lcd universal remote and charged unit 12 hours. The remote will not respond?????
    Problem Solver:
  • 12 Answers
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Posted on Aug 31, 2008
Need a battery for my mx-3000
It looks like there are two generations of this battery. I have located one with the small white connector. It looks like the part number for your battery is BTPC56067A. I have posted a link to the battery below:
Replacement BTPC56067A Battery for Universal MX-3000 Remote
Nov 12, 2012 | Universal Remote Control MX-3000 LCD...
Where can i purchase a battery pc 046067h for my MX-3000 remote in the Denver metro area ? my current battery needs to be charged daily....think its out of gas.
Amazon.com sells them. MX-3000 replacement battery @ Amazon Should be a pretty simple replacement, possibly a few screws on the back, use care when removing the old battery, as sometimes these connectors can cause damage from bending the pcboard it is attached to, same with installing the new battery. Don't be afraid of it, just treat it like a lady and it'll make you breakfast. Well, probably not. Good luck!
Thanks for using FixYa!
Dec 04, 2009 | Universal Remote Control MX-3000 LCD...
Get yellow band saying that there is no power. Do I need a new battery?
If you've tried charging it, and resetting the unit, then yes, its time for a replacement battery - which luckily isn't too expensive.
Here's some links for replacements...
http://www.google.com/products?hl=en&client=firefox-a&rls=org.mozilla:en-US:official&hs=lLL&q=mx-3000+battery&um=1&ie=UTF-8&ei=sHOySq3HO47ssQOMiLmeDQ&sa=X&oi=product_result_group&ct=title&resnum=1
Hope this helps! Good luck!
Sep 17, 2009 | Universal Remote Control MX-3000 LCD...
Where can I purchase a Lithium battery 046067 for an MX 3000?
Do you favorite search engine and type your model number and then batteries. What I got is www.buy.com
Aug 18, 2009 | Universal Remote Control MX-3000 LCD...
Power Card will not hold charge cannot find replacement
the battery may be faulty or the charger. try a different charger and see what happens. one of them is the problem good luck.
Mx 3000 screen is locked -does not respond when taken from charge
Take out the battery and reboot, or press and hold main for 10 seconds and reset to factory settings. If that does not work I can help you with more testing. Visit my site (www.totalcontrolremotes.com) and I will help.
Regards,
Vincent
Jan 17, 2009 | Universal Remote Control MX-3000 LCD...
Battery needed for MX-3000
My company carries a replacement battery for the MX3000.  The p/n for our replacement is PC036067-(V1 or V3 suffix)  You can reach me via email at sales@thebatterystore.net and I will be happy to help you.
There are three important considerations concerning this battery.
1) Please note that the original version, supplied by Universal Remote p/n PC046067-H for the MX-3000, was discontinued by the battery manufacturer.  The PC046067-H had a typical capacity of 1800 mah.  My company has worked with the manufacturer to provide a replacement that has a typical capacity of 1400 mah but is identical in size to the original although slightly thinner.
2) Universal Remote used two different connectors on the PC046067-H with no deviation of p/n.  We carry our replacement with both connectors (our p/ns use suffix V1 and V3 to differentiate).  V1 is a simple white plug and V3 is different in that it has pressure tab built in.
4be360b.jpg V1
d5dee3e.jpg V3
Oct 09, 2008 | Universal Remote Control MX-3000 LCD...
Mx-3000 just froze up
This happened to me today. I plugged the programming cable into the MX 3000 and the screen became "un-froze."
Jan 08, 2008 | Universal Remote Control MX-3000 LCD...
MX 3000
hold down the main button for 10 seconds... Hit factory default... Re download your program
Oct 24, 2007 | Universal Remote Control MX-3000 LCD...
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
397 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
