Question about Intel SS4000-E (SS4000ENA)
Disjoin SS4000-E from active directory
We are currently facing serious issues with our Active Directory.
Our Intel SS4000 is not accessible anymore and to solve this we need to Disjoin it from the current Active Directory domain and rejoin it under another name ...
However , there seems to be no way to change the storage device name ??
Any help or suggestions would be very much appreciated
  • 4 more comments
  • chatbiz Sep 21, 2008
    Same problem, its seem that only solution to change the name is to change Authentication Mode that will lead to data loss, I`m desparado please help!
  • Anonymous Oct 21, 2008
    I have the very same problem. As the NAS has been untouched, I can only conclude that something had been altered in a recent M$ hotfix to screw things up.
  • grogger Nov 20, 2008
    It appears that it doesn't matter what authentication mode you are in. The unit will show up in whatever workgroup or domain you set, but when you try to connect to it in Windows Explorer, you get a message saying: "\\unitname is not accessible. You might not have permission to use this network resource.... The network path was not found."
    I also saw on Intel's site that this unit has been discontinued.
  • jppires Jan 07, 2009
    Same problem, can't update anything from active directory. Two years working well and now without any reason no connection to ad.
  • PtochosMan Feb 06, 2009
    Same problem here, no one can access the folders. Sync with AD fails. Looks like the only solution is to switch back to local authentication mode, which will wipe all the data away. Loosing the data is not an option, so I have to find a fix for this.
    I have the same issue, it won't sync with AD, so no one can authenticate, so no one can access their folders. Switching modes deletes the data - which is not an option. http://www.intel.com/support/motherboard...
  • 922 Answers
If a computer is a member of a domain you need to logon using the local administrator account to change the name.
Another method, which takes a little more time is to remove it from the domain, rename it and then add it back.
Remember to restart after each change.
You may also have to go into DNS and WINS and make sure that the old name is removed and the new name is associated with the IP address.
If this helps please vote for my solution.
Posted on Sep 12, 2009
Yahoo support phone number
Please go ahead and try the below mentioned steps and check if that helps : .
In Exchange Server 2010, you may also experience this issue if the Exchange Servers group does not have the appropriate permission to the mailbox object in Active Directory. The most common cause for this is broken Access Control List (ACL) inheritance in Active Directory.
To check whether inheritance is disabled :
Open Active Directory Users and Computers.
On the menu at the top of the console, click View > Advanced Features.
Locate and right-click the mailbox account in the console, and then click Properties.
Click the Security tab.
Click Advanced.
Make sure that the check box for "Include inheritable permissions from this object's parent" is selected.
Let me know if that resolves the issue for you.
Aug 18, 2014 | Apple iPhone Cell Phones
Ldap connection issues. Issues connecting to LDAP Active Directory server on port 389. Search base setup as dc=domain,dc=local
You need to change the base DN to match your active directory domain.
So, if your active directory DNS domain is: example.com then your DN would be: dc=example,dc=com
Hope this helps.
Dec 07, 2010 | Panasonic DP-6010 All-In-One Printer
How we can remove active directory in windows 2003 safe mode ?
hello,
you just try to remove as force.
go to run, after this type " dcpromo /forceremoval ".
it will do this for you, if any issue on active directory or ad database.
you can do this command in normal or safe mode.
thanks,
Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Active directory is rebuilding
if u edit settings in active directory and editing the rools
bake up your setting
and remove active directory
them stup it agien
Nov 06, 2008 | Microsoft Windows Server Standard 2003 for...
Active directory
hello,
we have a following command option to open active directory:
dsa.msc
thanks,
Sep 30, 2008 | Microsoft Office Outlook 2003 for PC
DNS
DNS is the primary name resolution service for Windows Server 2003. Active Directory depends on DNS for domain controller location, and DNS influences Active Directory domain naming. Thus, to fully understand Active Directory, it helps to understand how DNS acts as an integral component in the design of Active Directory.
DNS provides Active Directory with both a name resolution service for domain controller location and a hierarchical design that Active Directory leverages to provide a naming convention that can reflect organizational structure.
Typically, a DNS domain namespace deployed to accommodate the Active Directory mirrors the Active Directory domain namespace. In cases where there is an existing DNS namespace prior to Active Directory deployment, the DNS namespace is typically partitioned for Active Directory, and a DNS subdomain and delegation for the Active Directory forest root is created. Additional DNS domain names are then added for each Active Directory child domain.
DNS data is used to support the location of Active Directory domain controllers also. During or after the creation of the DNS zones used to support Active Directory domains, the zones are populated with DNS resource records that enable network hosts and services to locate Active Directory domain controllers.
PS: As sourced from Microsoft Technet Site
Jul 24, 2008 | Microsoft Windows Server Standard 2003 for...
Regarding ActiveDirectory Services in Windows system
Active Directory (AD) is a technology created by Microsoft that provides a variety of network services, including: using the same database, for use primarily in Windows environments. Active Directory also allows administrators to assign policies, deploy software, and apply critical updates to an organization. Active Directory stores information and settings in a central database. Active Directory networks can vary from a small installation with a few hundred objects, to a large installation with millions of objects (though not easily [3]).
Active Directory was previewed in 1996, released first with Windows 2000 Server edition, and revised to extend functionality and improve administration in Windows Server 2003. Additional improvements were made in both Windows Server 2003 R2 and Windows Server 2008.
Active Directory was called NTDS (NT Directory Service) in older Microsoft documents. This name can still be seen in some AD binaries.
There is a common misconception that Active Directory provides software distribution. Software distribution is run by a separate service that uses additional proprietary schema attributes that work in conjunction with the LDAP protocol. Active Directory does not automate software distribution, but provides a mechanism by which other services can provide software distribution.
Jul 01, 2008 | Microsoft Windows Server Standard 2003 for...
Can´t CONNET to AD
You have to make sure that the clock of your NAS is synchronized with the ActiveDirectory. Configure your NAS to use NTP. This should be under the clock configuration screen. Enter the IP address of your domain controller(s) as the NTP server address.
Also, it would be a good idea to make sure that you domain controllers are synchronized with a root time source (on the Internet). In order to do that, run the following command on all you DCs.
C:\>net time /setsntp:br.pool.ntp.org
Of course, your DCs must be able to access the internet on port UDP 123.
Judging by your email address, you seems to be located in Brasil. If you are not in Brasil, you may look for another NTP server http://support.ntp.org/bin/view/Servers/NTPPoolServers
Feb 02, 2008 | Intel SS4000-E (SS4000ENA)
Active Directory authentication problem
* see netlogon service is running on the server * verify the srv record on the server ( http://support.microsoft.com/kb/816587 ) *see all authentication on the DC *check the event viewer if any error is occured *veryfy the DC http://support.microsoft.com/kb/816106 thanks Arun
Jan 13, 2007 | Intel SS4000-E (SS4000ENA)
Open Questions:
Greetings, I've been using the Intel Entry Storage System SS4000-E as a simple backup network drive for the last few years. It showed up as Drive Z: on all of my Windows machines and I just copied other drives/folders onto it as needed. It's far from the full capability of this device but it's suited my purposes. Recently, I decided to upgrade the drives and increase the total storage space from 2 TB (4 500 GB drives, Raid 0) to 6 TB (4 1.5 TB drives). The software doesn't allow me to make one 6 TB drive, so I made three (X:, Y:, and Z:), with sizes ranging from 1.49 TB to 1.99 TB, accessible as \storage\public3, \storage\public2, and \storage\public1 respectively. I also created the required shared folders using the minimum (200 MB) for both so I could have as much room as possible for large shared partitions. I also took the opportunity to upgrade the firmware to version 1.4, build 709, since I was installing new drives. I backed up some data to the Z: drive (\storage\public1) and filled about 1.5 TB. Then I started copying folders from another system to Y: drive (around 900 GB in all). Everything seemed to be going well until I looked in on the copy after around 800 GB had transferred. Files were being copied *extremely* slowly, like 100 MB in 10 minutes! I aborted the transfer and ran a test to eliminate network issues as the problem. I tried copying a 100 MB file from Y: drive to Y: drive. It took around 10 minutes, as above. I tried the same thing on Z: drive and it was almost instant. Something was somehow causing that part of the network drive to move at a snail's pace. I then accessed the management screen via a browser and got a message saying that one or more drives had either failed or been changed (Disk Change Notification - raid_disks_changedF.cgi). Two tables that show all four disks - serial numbers and capacities - are shown, one table being previous configuration and the second being current configuration. Both tables are completely identical. Clicking on "Scan" or "Continue" resulted in the same message, so I clicked on "shut down" and tried to access the network drive after it rebooted. I had no problem getting into the Z: drive part of it but both X: and Y: weren't being seen at all anymore. I'm aware of the fragility of a Raid 0 and wonder if it could be so easily disrupted during a large transfer such that I face the possibility of initializing all four drives and starting over. I'm at a loss as to what could be going wrong here or how to fix it. I really just want a simple means of copying lots of data over from various networked machines without any additional software. This system worked fine before. What could have happened? Thanks for any help. Bob
Apr 13, 2011 | Intel SS4000-E (SS4000ENA)
See all Intel SS4000-E (SS4000ENA) Questions
Intel SS4000-E (SS4000ENA) Logo
1,038 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
