Question about Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite My Kenmore elite HE31 is flashing the code HF when it gets to the spin cycle. It turns off and starts beeping about 17 mins into the cycle. It is a washer. What do I need to do? I won't work. Thanks I have a similar problem with the "HF" code. I've checked the water hoses going in, and much to my chagrin, there were no screens. I've put new screens in, but continue to get the HF error on both warm and cold wash cycles. Water seems to be flowing in just fine, but I noticed a "kick back" on the drain hose around the same time an error would show up (usually at 44 minutes and 18 minutes left on the Normal cycle). I disconnected the drain hose from the standpipe drain and let it drain freely into the nearby utility sink. Although I heard a little sucking through the drain hose, the machine finished the cycle. I was able to do a second load of laundry without any errors by draining into the sink. I'm still testing (and I've got lots of laundry to test). Is the sucking normal? Could my machine be full of sand? If so, how could I clean it out? My extended warranty expires very soon, and I'm wondering if this is a washer problem that would be covered, or a slow septic issue [though I haven't seen slow septic elsewhere], or just a washer problem that wouldn't be covered by warranty that I could perhaps fix myself.
  • 3,230 Answers
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
hope this helps.....
Posted on Mar 28, 2009
  • 56 Answers
Clear the button trap its takink to long to drain its under the front panel
Posted on Jun 29, 2009
    Genius:
  • 1,028 Answers
Don't worry about noise if it works don't knock it..you probably mean FH instead of HF ..you probably solved your problem when you pulled it from standpipe ..if drain hose fits too tight in standpipe water will siphon from machine and could cause the FH code
Posted on Aug 30, 2008
Kenmore elite HE31 front loader will not start but has power
This seems to be a problem in the start switch diode. If all works fine, but will not push and start and all cycles seem to work when working it manually, this is in the switch timer electronic diode is not working properly. Sometimes a code will not come up, because cycles are still working when manually changing wash cycles. There is seperate switch or electronic trigger that starts the machine, and has probably worn out or not making good contact. If you can unplug machine and then take off panel, trying spraying behind start switch with electronic cleaner to free up any possible dust or dirt. Might get lucky.
Apr 07, 2012 | Kenmore Elite HE5t Washer
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite
The HF error code is a hot fill valve control issue. Here are some tips:
  • If there is no water in the unit:
  • If there is water in the unit:
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation.
This is directly from the Whirlpool tech sheets we use to verify these problems. Make sure you have the hot water on fully and the hoses and strainers inside (at the fill valve and hose connection) are clean and debris free. let me know if this helps you out any.
Feb 21, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
486 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
