Question about Panasonic TH-50PV30 50 in. Plasma Television
Black bold line on panasonic plasma screen
I have a 50" plasma display screen. A bold line has developed in the middle of the screen. At times it displays. I am desperate to get rid of it. Please help
  • Panasonic Master
  • 13,433 Answers
Hey,
Your problem goes outside of my expertice, I would recommend you ask http://www.fixya.com/users/slinteriors Slinteriors for help, send him the problem, hes one of the best TV experts we have on this website I'm sure he can solve your problem
Thanks,
Ekse
Posted on Aug 29, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
How do i get rid of a horizontal line
It is a bad LCD. It may just be bad timing. Buy a new display on eBay for $50 and look up a video on how to replace the LCD on your particular laptop model. When ordereing, make certain to order the correct display! Matt finish versus glossy and screen size.
Aug 29, 2015 | Acer Aspire V5-122P-0864 11.6" Touch...
TH-42PX60B black vetical lines
If vertical lines are displayed to plasma displays, the fault should be with COF boards. These units can be located at the bottom side of the screen [in a row]. If its connection to panel become loose, this type of fault can occur, and is my experience. Check all the COF connections first. See whether IC used on each COF is damaged or not. You can't check it by using a multimeter; only can do a visual-test, whether there is any break or small holes on this IC. If you wish to get more details, check the site linked here. It has screen-shots to fault plasma displays. You can note it, and compare to that of your TVs' screen, and make sure about the fault.
google.com/+GopakumarGopalan
Nov 25, 2013 | Panasonic TXNC21BJTUJ C2 Board TNPA3813
My lg 50 inch 50px950 has a line down the middle
There are many reasons for this fault. A loose contact to COF, or a display panel fault. If you wish to make it sure, check the site linked here. It has screen-shots to defective plasma screens. You can compare them with your TVs'. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 12, 2013 | LG 50PX950 50" 3D Plasma TV
Have a Samsung 50" plasma tv with horizontal black
There are two possibilities for this fault. If COF module has any loose contact, or, display itself. If you wish to get more details about these type of fault to Plasma display, check the link given here. It has screen-shots of defective plasma dislay. Compare them to that of your TVs' and make sure. http://electronicshelponline.blogspot.com/ View it in Timslide option.
Jun 30, 2013 | Televison & Video
I have a 50" plasma insignia and it has colorful vertical lines down the middle.
Lines can be caused by a number or things: bad main board (control) which is rare, bad or loose plugs or solder connections.
The worst case is the issue (connections etc) can also be inside the display panel (PDP or plasma display panel) where they cannot be got at.
Parts for brand listed are not real easy to find in some cases.
Nov 05, 2012 | Insignia 50 in. Flat-Panel Plasma HDTV
My 50" Plasma has developed a band across the middle of the TV
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If you don't have the reciept then call 1-800-SAMSUNG.
Jan 24, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Feb 11, 2008 | LG 50PX4DR 50 in. Plasma TV
Panasonic TH-50PV30 50 in. Plasma Television Logo
174 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
