Question about Toshiba Satellite A45-S250 Notebook
Toshiba a45 restore problem
I attempted to use the factory recovery disk to re-install windows xp.
it went about 20 minutes through the process of re-formatting the disk, then informed me i had some sort of a hard disk problem, and now all i have is a black screen with a blinking cursor in the upper left hand corner.
turning the machine off and back on with the recovery disk gets the same result.
suggestions?
    President:
  • 2,961 Answers
Did the drive fail to boot initially and thats why you did a recovery unfortunately the hard drive has either failed and must have a damaged sector,or the recovery partition on the drive is stopping the format, which will more than likely be the problem.
The recovery disc you have won't be a full windows copy only a restore disc for your notebook, and it will look for a backup folder residing on another partition on your drive.
The only way to get a full format is to use a freinds copy of windows to format it and then install windows using your product key code on the underside of your notebook, unless you buy a copy in which case use the code provided
Posted on Aug 29, 2008
Restore factory settings
Many Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden system recovery image, you can restore your computer to its factory-fresh software condition by following these steps:
  1. Make sure the computer is turned off ("Shut-down" from the Windows Start menu)
  2. Remove any peripherals such an external mouse, keyboard, monitor, USB flash drive etc.
  3. Make sure the AC Adapter is plugged in and working.
  4. Press and hold down the 0 (zero) key on the keyboard while powering on the computer. Release it when the recovery warning screen appears.
  5. If the recovery process offers a choice of Operating Systems, select the appropriate one for you.
  6. A warning screen appears, stating that when the recovery is executed all data will be deleted and rewritten.
  7. Click Yes to continue.
  8. When the Toshiba Recovery Wizard opens select "Recovery of Factory Software" or the appropriate option for your needs.
  9. Continue to follow the directions restarting as necessary.
For laptops equipped with Windows 8, "Reset" returns your computer to its out-of-box, factory default conditions (removes your personal files and apps as well reset all settings to defaults) similar to a "System Recovery."
Please note that the process may vary slightly from machine to machine, that you may be asked to insert disks (multi-disk packages) and that the process may take one to two hours to complete. The recovery process will restart your computer several times.
As you use the recovery process you will have several options. One of these may be to create a custom size partition. Follow the directions on screen for this and other options as prompted. When in doubt, it's usually best to accept the default, or pre-selected option.
Nov 30, 2013 | Toshiba Satellite A45-S150 Notebook
Toshiba no bootable device--insert boot disk and press any key
try booting from a Windows installation disc. Choose the repair installation option. If this does not work, you may have to erase (format) your whole drive and start over again by reinstalling Windows from scratch.
Before erasing the drive, you might want to pull it out, put as a second drive in another working computer or inside a USB hard drive case and download all of your information from it. Otherwise you may have a mess on your hands with lost data/documents/photos.
Jan 21, 2013 | Toshiba Satellite C655D-S5084 Laptop
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
How to install operating system
If you do not have the restore disks or a restore partition, you need to take this PC to a IT Professional to have it loaded for you. This will entail the Operating System, Updates, Drivers, and 3rd party antivirus and anti-spyware.
Aug 26, 2011 | Toshiba Satellite P105-S6197 Laptop
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
System restore factory settings no cd
Toshiba has built in system recovery partition in your hard drive
Make sure to back up important files in your Laptop to usb or portable hard disk before doing this.
Warning: In using System Recovery you files will be deleted, your laptop will be back to its factory settings
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Feb 01, 2011 | Toshiba Satellite A45-S120 Notebook
I NEED TO RESTORE MY TOSHIBA LAPTOP TO FACTORY
Since Toshiba doesn't sells or replaces them the best solutions for you are:
1 - get an Windows XP install disk of the same type as the one on your pc and install with it while using your key - in this case you will gonna find and install all the drivers yourself
2 - just borrow from someone an recovery disk for your laptop; even one for a similar laptop will do, as long it's an Toshiba Satellite A series -  some drivers will be missing, install them yourself.
Jun 05, 2010 | Toshiba Satellite A100-S8111TD Notebook
Installing XP
Acer computers come with a factory restore partition installed from the factory. The following instructions are direct from Acer's support website:
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
  1. Enter the password created when eRecovery was first started.
  2. Read the on-screen warning and choose Yes.
  3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 18, 2009 | Acer TravelMate 4230 Notebook
New Hard Drive, system recovery problem
The systems disc is for the drivers and utilities, and, yes, there should have been two discs with the machine. The A45 is new enough that it should have come with an XP disc, not 98. I believe there was a mix up and you have the wrong disc. If you can get the operating system to load with the recovery disc you have, then you can get the drivers at the link below. Some two disc sets will not load an operational system unless you have both discs. Since you were running XP before, I don't think you're going to be happy with 98. I'm going to suggest that you purchase an XP disc, or contact Toshiba, and let them know that the wrong disc came with the machine, they might send you the right disc. If you do have to purchase an XP disc, simply load the system, then go to the link bellow and download the drivers. If you need any further assistance, feel free to ask.
Aug 14, 2008 | Toshiba Satellite A45-S150 Notebook
Toshiba Satellite A45-S250 Notebook Logo
146 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
