Question about Belkin Computers & Internet
Bought new desktop and would like to know if I can transfer my data and files from my old PC useing your cables?. Or, do I have to pay Staples $99.00 to do this for me?
  • Steve Mihaly Aug 29, 2008
    I'm not as proficient on the PC as I'd like to be. You specificed data files only. Actually, I want everything on the old PC to transfer to the new PC.
    Sound like what you're suggesting might take a bit more experience in electronics than I possess?
  • 4,234 Answers
If all you want are data files without programs, I usually recommend that the hard drive from the old system be mounted inside the new system as a secondary drive. That way you have access to everything.
Dan
Posted on Aug 29, 2008
  • ABRsvcs Aug 29, 2008
    Nope, this should be the simplest. You will need to change one jumper on the disk to change it from Master to Slave. Other than that, you should be good. Ask Staples how much to insert a second drive that you supply. This would be either the D or E drive depending upon how the new system is set up. That would give you access to the entire disc.
    Dan
Need to know the best way to transfer file from
Can simply: Burn files to cd/dvd's
Thumb Drive
transfer them over a router network.
Can also do a usb to usb data transfer if none of the above are easily accessible.
Jul 18, 2010 | Dell OptiPlex GX620 PC Desktop
Data transfer between PCs
The easiest way is with a USB data transfer cable. You just plug it into both computers, run the software and select the data to move. The sit back and in just a few minutes the data is moved. You should be able to get the cable from a local computer store, if not contact us at the address below. We have them available for shipment to you, they run $18.00 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 14, 2009 | ATI POWERED BY RADEON 9200SE 128MB DDR...
Need to know how to transfer programs and files from old to new PC
There are three sets of items that you need to transfer.
It would be best to use an external USB drive and keep the data on the drive as a backup.
1. Settings (Internet favorites, desktop settings, cookies, address book, etc.)
2. Data (My Documents, and multimedia content)
3. Programs
It would be easy if the old computer was also a Dell; however, you can't simply "copy" to the new computer.
#1. Settings: There is a built-in utility called "Files and Settings Transfer Wizard". [Start] [All Programs] [Accessories] [System Tools] [Files and Settings Transfer Wizard]
#2. The transfer wizard has an option to copy "settings only", "Data Only", Settings and Data". Transfer only the settings and then transfer the data. It will go much smoother.
#3. Some programs are already on your new computer; however, unless the old computer was also a Dell, you will have to re-install most or all of your programs like MS Office, Printers, Scanners, Camera and Video applications, etc.
If you need more detail, please post a comment... Thanks .
Oct 08, 2009 | Dell Dimension 4600 PC Desktop
Have been using Mozilla Thunderbidr for email. Have a new computer and have Mozilla Thunderbird seet up there - would like to be able to transfer old emails (kept for reference) to the new computer. Have...
Now-a-days the storage space of an email provider is so huge that you can access them using any PC with internet unless you have deleted from the server. If so transfer all emails to a separate HDD, load your new OS and transfer the data back......................sodeep
Sep 24, 2009 | Dell Dimension 4600 PC Desktop
I would like to know how to transfer data and software from a old computer to a new one I am considering to buy.
There are a couple of simple and fast ways to do this. They both depend on the systems. If you have two systems that both have network interfaces on them, the simplest way to trasnfer the data would be to connect the two computers together using a router (Linksys WRT54G about 60.00 at Staples). You can then share the drive on your old machine, and copy your data to the new machine using your network.
The second, which is slower but cheaper, is to buy a USB flash drive. 4 GB should cost about $25.00. When this device is inserted into a USB slot, it acts as a second hard drive. You can copy data from the old machine, to this and then move it to the new machine.
Good Luck
May 23, 2009 | HP Computers & Internet
How to get files from old computer to transfer to new one
u can take backup of data by harddisk to harddisk.
Connect your old computer harddisk to new computer then simply power up the new computer then u find both harddik then simply take backup of old data to new computer.
Apr 22, 2009 | Computers & Internet
I've purchased a belkin usb 2.0 file transfer cable for transferring old files from a pc with windows 98 to a new laptop with vista, the transfer cable is not picking up the two computers on the old screen...
Hi
Im not sure you can transfer over a USB cable with different OS and filesystems. easiast way is to buy a usb harddrive or usbstick copy data to that. or if the old computer have a networkcard to transfer over a crossover cable or true a network Hub/switch..
Aug 13, 2008 | Belkin Computers & Internet
I have purshased Belkin Easy transfer cable to tranfer data between my old Laptop and new one (old using windows xp new one vista home)I does not appear to work.I have loaded the CD as requested but idoes...
use the Files and Settings Transfer Wizard instead of the Belkin software. It's pretty straight forward in the steps for moving files to "new" computer.
Jun 09, 2008 | Computers & Internet
Data transfer
What I suggest you do is use the file transfer wizaed that is built n in WinXP OS's. From you old Dell go to start>Accs>System tools> file and Transfer wizard.....follow the prompts and save the file to your desktop. After the coolection and creation of the UMT2 folder copy it to a flash drive or use a cross cable between your old and new laptop and share the folder in th network s you can access it directly from your new laptop. Copy he whole folder to the desktop of your new Laptop. Run the same wizard on your new laptop.
May 21, 2008 | Lenovo ThinkPad T61 Notebook
Computers & Internet Logo
46 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
