Question about Yamaha RX-V870 Receiver
Output volume varies, with loss of bass and clarity
Audio volume varies, with loss of clarity when on for a little while. If I remove either input channel and only play one channel, it comes back to proper volume. It does the same with either channel disconnected.
Q. Would this be related to the power output stages, and possible just the power tranistors?
  • NevilleH Aug 29, 2008
    Thanks Dan - makes sense could be a power supply problem. Hopefully is just fault capacitors, or maybe the regulators. Might have a look at them myself and source some spares. Thanks and I will let you know how it goes.
  • 4,234 Answers
This sounds more like a power supply problem. I would have the voltaeg regulators checked along with the filter capacitors in the power supply area.
Dan
Posted on Aug 29, 2008
Connecting a turntable?
If you have a Phono input it will provide the additional amplification needed for the ceramic cartridge, and perhaps even more amplification for a magnetic cartridge, made available by a switch. It also has extra bass boost to counteract the lack of bass in the recording, done so as to keep the grooves from making use of lots of platter real estate. By minimizing the bass, the recording time is increased.
If you don't have a Phono input, but you have an aux input, you may have to crank the volume and the bass to get reasonable sound, because the phonograph cartridge doesn't produce much output as compared to "line-level" devices such as a line-out on a tape deck.
Apr 09, 2014 | Sony CMT-CP101 CD Shelf System
I need someone who actually knows about audio and particularly MOTU microbook and headphones. I do voice transcription through headphones and am looking for clarity in audio but also a little bit of...
The realtek chip should come with the HD audio manager in the control panel if the drivers were installed correctly.
You'll want to check and make sure the equalization (under the sound effects tab) is set to none, or possibly to treble (I had to use the treble setting on mine if using a sound system with a subwoofer).
Another trick to raise the frequency of the audio is to raise the "Karaoke setting which will pitch shift all frequencies upward.
Jul 21, 2011 | Computers & Internet
Is the bass boost the gain or frequency knob?
Bass boost simply adds DB or gain to the bass signal. Some like it, some dont.
The frequency knob is the Low Pass Filter (LPF) that cuts off the amp output above
the set frequency. A bass system usually cuts off below 400 HZ and more often 200HZ.
A good, rattle your car bass note is in the 25-80HZ range or lower but most amps and audio
input devices cant attain a good low note with clarity.
"Low-pass filter allows only frequencies below the crossover point to be amplified. A high-pass filter allows only frequencies above the crossover point to be amplified - useful for keeping low bass away from small speakers, so they can play more efficiently."
Checkout Crutchfields Glossary of Car Amps.
http://www.crutchfield.com/S-LPyoWWgD5qN/learn/learningcenter/car/amplifiers_glossary.html
Mar 14, 2011 | Rockford Fosgate Car Audio & Video
Don't know how to connect to tv
If the TV has audio output available, there will be RCA jacks somewhere for that. The standard colors are red for the right channel and white for the left, and they'll be clearly marked as audio outputs. Not all sets have audio outputs, though, while they usually have audio and video inputs. So if you find RCA jacks on the set be sure to see how they are marked.
If the TV has output jacks, all you need is a cable with the appropriate plugs at each end. The TV needs RCA plugs, while the input connector to the speakers varies by manufacturer. Typically the speakers will use a 1/8-inch stereo jack if they were made to be used with a computer, and RCA jacks if they were meant to be used in a home-theater setting. In TV sets with audio outputs, the output may be fixed and independent of the TV volume, which means you can turn the TV volume down and use just the external speakers. Or the audio output may vary with the TV volume, meaning you'll always need to have the TV volume on as well. Some people find this annoying.
If the TV doesn't have an audio output available, you can't hook the speakers to the TV. What most people do in that case is use the TV as a video display in conjunction with an AV receiver. The audio and video sources connect to the receiver, which in turn drives the speakers and provides a video output to the TV.
Feb 27, 2011 | Durabrand 5.1 Surround Sound Computer...
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
We want to know can we put an mp3 player or the like through the original audio gear . if not can you advise us on what we can do . we have the tape deck which is not good now thanks
Does you sound system have an input plug (RCA) of audio?
If does you could buy a cable adaptor that have an output of stereo rca. Plug the stereo jack on your mp3 earphone socket and your ready to play!
If your sound system have no audio input. You should buy a 12 volt amplifier, with an out put of 50 watts( Depends upon your clarity and bass boost) or higher! Use your existing speakers and make sure you buy that audio adaptor cable for your mp3 to connect to your brand new amplifier.
Thanks for using Fixya as a problem solver!
Dec 07, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
I own a hk 12x2 and put it in a 2 cube inch sealed enclosure. will it sound better in a ported or bandbass
ported is the loudest your going to get as you get sound from the front and the rear of the sub compared to hearing only one side in a sealed or bandpass box.Bandpass boxes are very loud near there tuning frequency but tend to sound offish at tones that aren't near the tuning frequency. The same with ported boxes and the bass will tend to be a little sloppier compared to the tight bass of a sealed enclosure- it comes down to your musical preferences- more sound at the cost of clarity and loss of power handling capability or tighter cleaner bass with added power handling.
Jan 01, 2010 | MA Audio HK12X2 Car Subwoofer
Amp sends power to sub at low volume. but when volume is increased speaker loses bass and distorts REALLY BAD. Still has power but clear bass disperses. just sounds terrible at even lower volumes
are the sub speakers ok? if ok then u have a problem with the Amp and the output IC's will have to be checked there cud be a problem with the input card in the amp.
Aug 26, 2009 | Jl Audio 500/5 Car Audio Amplifier
What to do
Hello dodgeram1980,
If you are not getting sound from any of the 4 channels, I'd suspect that either the amp is not getting an input signal or the amp itself is faulty.
Here's the "no sound" troubleshooting step-by-step procedure from the JL manual:
1) Check the input signal using an AC voltmeter to measure the
voltage from the source unit while an appropriate test tone is
played through the source unit (disconnect the input cables
from the amplifier prior to this test). The frequency used should be in the range that is to be amplified by the amplifier (example; 50 Hz for a sub bass application or 1 kHz for a full range / high-pass application). A steady, sufficient voltage (between 200mV and 5.O-volts) should be present at the output of the signal cables.
2) Check the output of the amplifier. Using the procedure explained
in the previous check item (after plugging the input cables back into the amplifier) test for output at the speaker outputs of the amplifier. Unless you enjoy test tones at high levels, it is a good idea to remove the Speaker Connector Plugs from the amplifier while doing this. Turn the volume up approximately half way. 5V or more should be measured at the speaker outputs. This output level can vary greatly between amplifiers but it should not be in the millivolt range with the source unit at half volume. If you are reading
sufficient voltage, check your speaker connections as explained below.
3) Check to ensure that the speaker wires are making a good
connection with the metal inside the Speaker Connector Plugs. The speaker wire connectors are designed to accept up to 12 AWG wire. Make sure to strip the wire to allow for a sufficient connection with the metal inside each terminal.
Hope this helps.
Apr 30, 2009 | Jl Audio HD600/4 Car Amp
Plugging a turntable into a harmankardon 147 receiver: where and how to get volume. The sound volume is too low.
The 147 receiver doesnt have an input for a turntable. THe output from a turntable is VERY low and is heavily equalized because of the actual record format ( the bass is cut way down and the highs are boosted.....when run through an actual phono input, it "un does" the equalization by boosting the bass and cutting the treble......this is called the RIAA compensation curve ).
You need wither a receiver with an actual phono input, or a good quality Phono Pre Amp....
Good luck... Rob
Apr 21, 2008 | Audio Players & Recorders
91 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
