Question about NetGear WGT624 Wireless Router
Wireless LED not lit. No wireless network. Hardware problem ???
Could this be anything other than a hardware problem?
May firmware update help ?
  • sldr Aug 31, 2008
    At the end - only factory reset solved the problem.
    Another wonderful feature by netgear....
  • 2,961 Answers
If you can get to the router menu settings the wireless may not be enabled, some are not as default, if enabled and no light then yes a faulty unit.
Posted on Aug 29, 2008
Wll an wis09abgn wireless adaptor fit myJMB tv
TV WIRELESS DONGLE - TV - Wireless Networking - Tom's Hardware
Tom's Hardware Guide
Mar 6, 2011 - 6 posts - ‎2 authors
do u know what dongle or wireless device can use to put on TV ?? like u all know samsung already have that dongle (Samsung WIS09ABGN ... Customer Reviews: Samsung WIS12ABGNX ..., Inc.Samsung WIS12ABGNX LinkStick Wireless LAN Adapter. bySamsung .... The manual for my Samsung HT D4500 specifically states that you must use the WIS09ABGN. ... If you have a Samsung LED smart tv you can make it wireless.
How to Use Samsung Wireless LinkStick with Samsung LED ...
? 1:41
Mar 26, 2010 - Uploaded by SPSN
The LinkStick is a wireless USB adapter that provides instant access to Samsung's ... Can any linkstick work with any Samsung 32 Inch TV?.
Jan 05, 2016 | Computers & Internet
How do I set security on my DWL-952
There are 2 possible areas raised by this question. The first is a security patch needed to fix the firmware of your router, which by the way is not dwl-952. Your router is a di 954. Dwl 952 is a bundled router and network interface. The details of the firmware update are below.
Security patch for your D-Link router
These firmware updates address the security vulnerabilities in affected D-Link routers. D-Link will update this continually and we strongly recommend all users to install the relevant updates.
As there are different hardware revisions on our products, please check this on your device before downloading the correct corresponding firmware update. The hardware revision information can usually be found on the product label on the underside of the product next to the serial number. Alternatively, they can also be found on the device web configuration.
Please make sure you follow the firmware install guide provided within the ZIP firmware package.
DI-524 Revision E1/E3Thu, 28/11/13
The new firmware 5.13b01 that fixes the security vulnerabilities
DI-524 Revision Ex 5.13b01
Please note: please unzip the file and use the file DI524Ex_FW513B01.bin to update firmware.
DI-524UP Revision A1/A2Thu, 28/11/13
The new firmware 1.08b02 that fixes the security vulnerabilities
DI-524UP Revision Ax 1.08b02
Please note: please unzip the file and use the file DI524UPAx_FW108B02.bix to update firmware.
The second possibility is to set the local security on your network.
From the wikipedia page:
Wireless security is the prevention of unauthorized access or damage to computers using wireless networks. The most common types of wireless security are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA). WEP is a notoriously weak security standard. The password it uses can often be cracked in a few minutes with a basic laptop computer and widely available software tools. WEP is an old IEEE 802.11 standard from 1999 which was outdated in 2003 by WPA or Wi-Fi Protected Access. WPA was a quick alternative to improve security over WEP. The current standard is WPA2; some hardware cannot support WPA2 without firmware upgrade or replacement. WPA2 uses an encryption device which encrypts the network with a 256 bit key; the longer key length improves security over WEP.
The complete article is here
Wireless security
Log in to your router and find the wireless security section. Set up the security model that best suits your needs and then set up your wireless network card with the same information.
Mar 11, 2014 | Computers & Internet
When i install the drivers for TP-Link WN353GD adapter, I already get a warning that it may not be compatible with my system. Currently i am running Win XP SP 2. Is there sometime i can do to overcome...
Update your Wireless Adapter firmware @
There are 3 versions for your product(TP-LINK TL-WN353GD, Important***select the correct firmware version to update. Then download the latest drivers(Setup Utility) & and install the drivers for your adapter from the TP Link site.
Link - How to look over the hardware version on a TP-Link device?
Hope it helps.
Apr 05, 2011 | TP-LINK TL-WN353GD 802.11g/b Wireless...
Wireless adapter crashes Toshiba Satellite A55
Try to update the wireless driver, also update the firmware (BIOS). it will fix your problem, it is software conflict.
Oct 04, 2009 | Toshiba Satellite A55-S1063 Notebook
D Link WNA 2330 wireless adapter not lit
Try to update the driver for the wireless adapter. Here is the link for that:
If this solution solves your problem, please rate me.
Apr 03, 2009 | D-Link Rangebooster G Notebook Adapter...
Thinkpad r40 - wireless disappeared
Go to the control panel, then System, then Hardware tab, then Device Manager. Then Network adapters - you should have two network adapters one LAN and one wireless.
If most likely have one, the LAN adapter and a yellow ? against a network adapter - this will be a wireless adapter (its not installed)
Check your BIOS and make sure the wireless card is enabled.
You need to download from the IBM/Lenove WEB site the wireless driver (there may be several types that is installed for your model laptop). Make sure you select the correct Windows version driver.
When you run the driver,it will uncompress and copy to your hard drive in C:\drivers. You can then install the driver from this directory. If it doesn't work then repeat with another driver, most likely one that works will be the Intel one.
Jan 24, 2009 | IBM ThinkPad R40 Notebook
Linksys WPC54GS wireless adapter installation issue
There's a possibility that the adapter is defective. However, you may still try the following:
1. Make sure to uninstall the software if you still have it installed. Remove it from the Programs list or under Add/Remove Programs.
2. Check Device Manager and make sure adapter is not under Network Adapters nor Other Devices. It might be called Network Controller if driver is not installed correctly.
3. Unplug card, shutdown computer and when PC is powered off, plug card back and restart computer.You may insert the CD on this process, but do not run/continue the CD setup wizard.
4. When computer is back on, you should get a Found New Hardware bubble message or wizard.
Just finish the wizard and tell me how it went. Goodluck!
Jul 08, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
It sounds like you may have a band PCMCIA slot. Have you attempted to use any other expansion cards in it to test this theory?
May 10, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
NetGear WGT624 Wireless Router Logo
42 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
