Question about HP iPAQ HX4700 Pocket PC
IPAQ hx4700 Installation
When I try to install the software from the CDROM I get an error message that says 'Member Not Found'. This happens as soon as I try to enter the setup wizard. My suspicion lies with the Windows Installer (I am using Windows 2000)but I am not sure. Does anyone have any thoughts?
    Master:
  • 450 Answers
Try to disable any security software (i.e. firewall, anti-virus) then go to My Computer, right click on the CD-Drive that has the Companion CD, select Explore and install the software manually from there on.
Posted on Sep 11, 2005
SOURCE:
M2n-mx bios problem
try new cmos battery
Feb 13, 2014 | Computers & Internet
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
A unknown error has occured. The application will close when you click OK
When poeple create software, they test it in order to discover programming errors, and all sorts of unusual conditions that may make the software misbehave. For every error found they design a customized message to let you the user know what happened and what you can do to salvage your work.
Error conditions may also be created by the user and the input he/she gave the software. In the testing phase, the testers try to think of all possible data (good and garbage) that the user may enter and design a message if the input leads to a software misbehavior.
But programmers and testers are not omnicient and sometimes they miss errors conditions. For all these, there is message telling you that an unknown error happened.
You may reduce the number of such occurences by familiarizing yourself with the software and its use.
Hope it helps.
Nov 21, 2009 | Transparent Easy Translator 4 Deluxe for...
How do i erase a hard drive with a os on it i need to install a hard drive on a pc but the os on messess up booting when i plug it it
press DEL key as soon as the PC is booting. it will enter BIOS, find "Boot priority" and change the "First Boot Device" to CDROM. then save and exit.
If you are installing Windows, watch out for the message "Press any key to boot from CD....." then follow on-screen instructions.
If you are installing Linux, it will boot to CD drive when it found the Linux boot CD.
Oct 15, 2009 | Computers & Internet
Can't boot with Cd-Rom unable to install windows XP
Well, maybe I can try, thus in your bios setting you can boot using usb cdrom? Or maybe its time to change your cdrom drive already. If you can borrow a good spare cdrom. Take this in for the meantime in exchange for your installed cdrom. Maybe your cdrom drive is faulty. Then if this is ok, it is now easy for you to get on.
Second option, you can take out your harddrive prime it, then have a partition (say d:\) with a copy of full copy of xp installer, and other important installer just have it foldered. Then I assume you can boot using a floppy drive with win98 rescue disk. After booting goto harddrive partition with xp installer. then click setup and set it up in c:\ . Then your go other software, installed it manually.
I do this coz it much faster to installed using harddrive and also it is only in xp.
Hope this helps. comments if I miss something.
May 05, 2009 | Microsoft Windows XP Home Edition
Installation of softwares
i hope the ipaq is a windows based mobile, or what is also known as pocket PC. If am right, then it will not support .exe applications. Google your requirements specifying that your's is a Windows based mobile..
please revert back for clarifications..
Jan 30, 2009 | HP iPAQ H6340 Pocket PC
Replacing PDA Screen - HP iPAQ hx4700
http://www.repairhppda.com/video/How-to-Repair-for-HP-iPAQ-HX4700-HX4705-series.html
Jan 19, 2009 | HP iPAQ HX4700 Pocket PC
OPERATING SYSTEM NOT FOUND....NO ACCESS TO CD DRIVE
Connect your external CDROM to the laptop. I think it is a USB CDROM. Enter your bios setup. In the boot device section, try to find any option which says First Boot Device -> USB CDROM. If you can set this things then the computer will be able to boot from your external cdrom.
Nov 26, 2008 | Sony VAIO GRX550 Notebook
HP iPAQ HX4700 Pocket PC Logo
93 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
