Question about Toshiba e400 Pocket PC
Data recovery after battery disconnect
I try (without knowing that a sandisk SD WIFI+256 MB seems not to work on an E400) to install it and after a reset the PDA doesn’t work at all (even a reinitialize won't work). So finally I decide to disconnect battery and reconnect. After that the PDA is back again but naturally the data from main memory are lost. There is some data recovery software able to recover something? (of course that i haven't any backup at all )
    Master:
  • 903 Answers
You are absolutely right. The “SD WIFI+256 MB” don’t work properly. Unfortunately there is no software that can re-establish your data again. You must be very carefully and always make data back up using SD card. This is the best and securest way to save all your data.
Posted on Sep 11, 2005
LG-E400 MANUAL RESET
All data will be lost! Remember to back up any important data before doing a hard reset.
When the phone is turned off, press and hold the Home key + Volume down key + Power key for over 10 seconds. When the screen shows the LG logo, release the Power key.
After the screen shows the hard reset screen, release the other keys.
Leave your phone for at least a minute while it performs the hard reset, then your phone will be turned on.
anothewr way is :
reset phone to factory settings and erase all the data on your phone, touch Menu > Settings> Privacy > Factory data reset > Reset phone.
Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card,
such as music or photos. If you reset the phone in this way, you are prompted to re-enter the same information that you did when you first started Android.
Oct 01, 2012 | LG Optimus E400 1gb Black Unlocked Android...
Sandisk 1 gb has 233 mb after formatting?how can i get my 1 gb storage spae back?
If the Sandisk 1 gb has 233 mb after formatting, then the card is usually bad and must be replaced.
Try doing a complete formatting again.
If that does not work, delete partition and try doing formatting with a tool like the one below.
If the software below does not fix the problem, then replace the card.
Sd Card Partition Software Downloads
Partition recovery software
Free download corrupt hard disk partition data repair software
Aug 02, 2009 | SanDisk 1GB microSD Memory Card
Recover lost files in sandisk 1gb micro cruzer
you need rely on professional file recovery tool to get them back. A popular one is this photo recovery. This tool can deep scan the memory card and recover your lost files back without requiring extra skills. Here is the steps might be helpful to you:
1. Connect the memory card to computer. Under "My Computer", note the drive letter assigned to your memory card (usually G: or H:).
2. Download this data recovery program on your compute. here is the link: http://www.asoftech.com/adr/
3. Install and start the program. then click on settings on top right part of the program, check videos and click OK.
4. select the drive where your lost files located, click Start. Now the scanning process will start to search the deleted files. After a while you will then get a list of recoverable files.
5. Press Recover to perform full recovery.
Jun 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Recovery mode
For those with the 4 GB model, try removing the SD card and powering completely off, without selecting any of the recovery options.  You will probably get prompted to recover when the device boots, click OK to recover - do not reinsert the SD card.  Perform a complete power off and power on cycle without the SD card.  If this works, reinsert the SD card and perform a power off/power on cycle.  If it prompts you to recover the system, the SD card is bad (the data can probably be read by the device after it has restarted, but will continue to cause the recovery mode).  Note that reformatting the card in the device does not seem to resolve the issue.  Try reformatting the card in a PC or digital camera (this option worked for me).
Jun 13, 2008 | Archos 605 WiFi Digital Media Player
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Pocket PC e400 en Sandisk WiFi
I have bought the Bluetooth Option Part for my e400. It was an "PC Bluetooth SD Card2". In the specs of the Bluetooth Card is an SD/IO enabled SD Slot required for the Card. So I think your Wifi will also work.
Sep 11, 2005 | Toshiba e400 Pocket PC
E400 with Sandisk 256mb + Wi-Fi
Sorry, Sandisk 256mb + Wi-Fi SD Card is not compatible with e400. Only Sandisk Wi-Fi SD Card without additional memory is working.
Panasonic SD card
> The Panasonic 256MB SD card is twice as fast as the cheap SanDisk > 256MB I bought from Costco for $65. Saving the 5-shot burst at > 4MP, the Panasonic card takes only 2-3 seconds to save, whereas the > SanDisk card takes 5-6 seconds. Although the SanDisk works just > fine in video mode - I was able to fill the card with video. The > extra speed is also very noticeable on the Panasonic SD through my > 8-in-1 SanDisk USB2 reader on WinXP copying the files to my hard > disk. > > Has anyone tried SanDisk's "ultra" or other performance versions? > Any reason why the Panasonic is so much faster? the panasonic SD is rated at 10Mb/sec. ditto for the Sandisk Ultra II. I've got both versions of the Sandisk. the regular Sandisk is only rated at 2 Mb/sec which explains the slow save speed. the Sandisk Ultra II is much faster compared to the regular Sandisk.
Sep 04, 2005 | Panasonic SV-AS10 Digital Camera
Toshiba e400 Pocket PC Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
