Question about Philips Magnavox 20MT133S 20" TV
Nhens convertor box www.dsconter.com
The converter box from radio shack does not pich any channels? i can get stations with out any antenna! with rabit ears i get almost perfect picture.The box wont program any stations.Which box should i buy? i am gonna return this one from radio shack! RICHFWV@YAHOO.COM
  • 4 more comments
  • richfwv Aug 29, 2008
    I bought a convertor box from radio shack! IT WILL NOT PICK UP ANY STATIONS AT ALL!!! i AM TAKING IT BACK!! does any one know a box that works? richfwv@yahoo.com
  • grandpiano Sep 08, 2008
    NHENS digital converter box does not show a Setup Wizard as described in the manual. Installation appears to be ok with TV, Converter, and VCR all set to channel 3. But there is no Setup Wizard. Email contact: support@dsconverter.com is rejected, and service number 1-866-706-4367 does not answer. Should I take this back to Radio Shack?
  • mcbbrown Jan 16, 2009
    i have black back ground and white lines and one remote works with converter box one works with tv.
  • Anonymous Jan 17, 2009
    same problem the equipment is junk.......I'm selling mine on ebay let someone else deal with it
  • Anonymous Feb 21, 2009
    the DTV converter box worked fine for about a week then stopped. The box will not program any stations. this is the second box I bought from Radio Shack.
  • gjmford Mar 15, 2009
    Same problem. I don't get it. Why the hell would someone make us have to do this and not give us the right stuff.
Remote will not turn off tv. Why
Posted on Mar 18, 2009
Posting regarding the NHENS converter in January 2009. Bought it at Radio Shaft and it works -- feeding an old Panasonic b/w TV on channel 3. Live within 25 miles of the Empire State Building and the converter has managed to pick up and lock up on all NYC signals but channel 13. Also brings in channel 41 (licenced to NJ) and its subchannels plus the nearby channel 58 and its NJN-2 subchannel. Antenna is an amplified indoor rabbit ears with a loop also from Radio Shaft perched atop a kitchen cupboard on the 2nd floor of our house. Apparently, NHENS managed to correct the above referenced problems.
Posted on Jan 20, 2009
Attach tv converter box
Everything is digital now. You will need a digital converter box. You will connect an antenna to it, and then connect the box to your tv. The box will come with it's own remote. Your tv will be set to channel 3 or 4 (depending on the converter box you get), and you will control the stations with the remote that came with the converter. You can get them at any electronics store.
Jan 09, 2014 | Jensen J53-BWR 5 in. Portable Television
I want to use an RCA F31224GG built in 1993 for OTA channels only. What type of converter/antenna do I need
You will need that converter box for the digital to analog system plus a out odf door antenna...radio shack is good place to ck...also ck out Amazon.com & eBAY
ck this outat Amazon.com http://tinyurl.com/m7xo528 for box
antenna here http://tinyurl.com/p2tsbra
Nov 13, 2013 | RCA Televison & Video
Program Radio Shack 15 2142 remote for converter box
only if the converter box is using older codes that were in use when the remote was made.
Mar 12, 2010 | Radio Shack 15-2142 Remote Control
Casio EV 550 B portable TV 3" screen many of "us" with portables are wanting a "FiX" instead of landFILLing our sets when the switchover comes apon us. Is there a DTV FiX? costs? Are there portable DTV's?...
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that connects to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Jan 26, 2009 | Casio TV-980 2.3 in. Handheld Television
Converter box Help
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
Jan 23, 2009 | Philips Magnavox 20MT133S 20" TV
Magnavox 20MF500T/17 will not interact w/NHENS DTV Converter box
The tv just needs to be set to channel 3 or 4 to pick the signal up from the converter box.
Jan 10, 2009 | Philips Magnavox 27MS343S 27" TV
Are there converters 4 hand held casio 880B
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
A few other tips:
Nov 11, 2008 | Casio TV-980 2.3 in. Handheld Television
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Hand held casio tv vs digital signal
A few other tips:
Apr 29, 2008 | Televison & Video
GE spacesaver 05GP009
I had this same problem, I wanted to use this tv with a converter box and the only way to do this was to hook up the converter box with an external antenna to the small 3.5mm input on the back. If you go to radio Shack and get an "F to 1/8" Adapter"the radio shack part number is "278-257". It worked perfectly. I'm able to get many clear channels, and with the converter box I now have remote control. It works well. Good luck, I hope this helps
Mar 02, 2008 | GE SpaceMaker 05GP009 Television
Philips Magnavox 20MT133S 20" TV Logo
1,826 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
