Question about Intermec EasyCoder F4 Printer
Error Code 1009 At 100009150
I have a problem that occurs from time to time, but i do not know what is causing it. I send identical data to two printer (only layout differ cus one is a mirror image), and i often get the error message "Error Code 1009 At 100009150". It usually happens on printer number 2, but have also happened on printer 1.
When i send a print i set up a tcp connection there and then, send the data, then close. Then i set up a connection again, and send the data to printer no 2, and close it.
I also tried only using one printer, but the same happens then aswell. Its random when it happens, sometimes it goes well, sometimes only 2nd errors, and sometimes it errors on the first thus blocking for the 2nd.
4 Suggested Answers
Dyes
  • 6 Answers
SOURCE: Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Posted on Aug 15, 2008
  • 148 Answers
SOURCE: Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Posted on Jan 04, 2009
  • 148 Answers
SOURCE: I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
How do i reset error c7911 on kyocera printer ?
C7911 Developing unit K EEPROM error
No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively.
Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively.
Possible Causes;
  1. Poor contact in the connector terminals.
  2. Defective developing PWB K.
Jan 12, 2015 | Kyocera Office Equipment & Supplies
Kyocera 5050 error code 2202
This is an error is indicating a connection error when using the send feature.
Below I have provided some information or for more information download the users guide from the manufatcures website using this link. http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=16088&rid=16313
2101, 2102, 2103, 2201, 2202, 2203, 3101:
The network cable is disconnected or the hub that it is connected to is not operating properly. Check the cable and the hub. Otherwise, the server name or the host name of the SMTP server is
not set correctly. Use COMMAND CENTER and register the SMTP server name and the host name
correctly.
2204: The E-mail size exceeds the acceptable send data capacity. Decrease the size or resolution of the scanned data to be transmitted and resend the E-mail. 5101, 5102, 5103, 5104, 7102, 720f:
Turn the main power switch off and back on. If this error occurs several times, make a note of the displayed error code and contact your service representative.(Refer to the corrective action for the error message " An error has occurred.")
9181: The scanned original exceeds the acceptable number of pages of 999. Send the ecess pages separately.
Hope this is helpful,
Shawn
Mar 11, 2011 | Kyocera Mita KM-5035 Printer
Error code e190 0000
Cause:
· The laser controller PCB is faulty.
· The CPU PCB is faulty.
Timing of detection:
An error has occurred while wiring
data to the laser controller PCB from
the CPU PCB at power-on.
Jan 25, 2011 | Canon CLC 1150 Color Copier
Sending email failed. Error code; #008.
Normally this error comes when you are sending any mail having some attachment.Sometimes when you send an attachment to somebody by Gmail, it will occur an error named 008, this is caused by the size of your attachment, it must be not larger than 25MB, now I will tell you about how to fix Gmail Error 008.
Symptoms:
While signing in or using Gmail, you receive this error:
Oops... (error code ###)
Cause:
A conflict with software on your computer, browser cache that needs to be cleared, or a temporary problem on the Gmail server.
Solution:
Follow the instructions below in the order provided. If they don't resolve your issue, you'll have a chance to report the problem to Gmail.
Which 'Oops...' error code are you receiving?
  • 007
  • 008
  • 009
  • 102
  • 103
  • 500
  • 602
  • 6413
  • Other code
If you see this error when sending an attachment, the attachment may be too large. Please make sure you're sending an attachment less than 20 megabytes (MB) in size.
If you've confirmed that the attachment is less than 20MB, follow the troubleshooting steps below to resolve the issue.
Please select any security applications you have installed for further instructions.
  • BellSouth Internet Security//Here i selected this one
  • eTrust EZ Firewall
  • Freedom Privacy and Security
  • Kerio
  • McAfee
  • Norton
  • Proxomitron
  • Telus
  • ZoneAlarm Pro
  • None of the above
Please disable your BellSouth Popup Blocker by following these steps:
  1. Click Start from your system tray and select Run...
  2. Type cmd and click Okay
  3. Type cd c:Program Files//BellSouth/BellSouth Internet Security and press Enter.
  4. Type regsvr32.exe/u pkr.dll and press Enter
If the above steps didn't resolve the issue, you can see if a browser extension or toolbar may be causing the problem. Browser extensions and toolbars are intended to enhance browser functionality, but they can interfere with Gmail.
Please select any extensions you have installed for further instructions.
  • Better Gmail
  • Firebug
  • None of the above
The Better Gmail browser extension may interfere with Gmail. If you are experiencing problems, please upgrade to Better Gmail 2
If you're still experiencing problems, clearing your browser's cache and cookies can resolve many issues in Gmail. Select your browser below for instructions.
What browser do you use?
  • Google Chrome//Here i selected this one
  • Firefox
  • Internet Explorer
  • Safari
  • None of the above
In Google Chrome for Windows and Linux:
  1. Click the Tools menu tools menu.
  2. Select Options.
  3. Select the Under the Hood tab.
  4. Select Clear browsing data.
  5. Select the "Clear browsing history" checkbox
  6. Use the "Clear data from this period" menu to select the amount of data you want to delete.
  7. Click Clear browsing data.
In Google Chrome for Macs:
  1. Select Chrome > Clear Browsing Data on the menu bar.
  2. Select the "Clear browsing history" checkbox.
  3. Use the "Clear data from this period" menu to select the amount of data you want to delete.
  4. Click Clear Browsing data.
Did this fix the problem?
  • Yes//Here i selected this one
  • No
We're glad to hear your problem has been resolved. Return to Gmail
Dec 29, 2010 | Google Gmail
Gmail Error code # 008 OOps error while sending
Symptoms:
Cause:
Solution:
  • 007
  • 008
  • 009
  • 102
  • 103
  • 500
  • 602
  • 6413
  • Other code
  • Kerio
  • McAfee
  • Norton
  • Proxomitron
  • Telus
  • ZoneAlarm Pro
  • None of the above
  • Better Gmail
  • Firebug
  • None of the above
  • Firefox
  • Internet Explorer
  • Safari
  • None of the above
  2. Select Options.
  • No
We're glad to hear your problem has been resolved. Return to Gmail.
Oct 12, 2010 | Google Gmail
When sending texts to certain numbers i get an error code 96 and the message will not send
Error 96 means you need to dial in the whole phone number...example 17085551212, not just 5551212 even if you are sending text message to the same area code.
Nov 29, 2009 | LG RUMOR Cellular Phone
I can not send a message to friends Transport error (#1001) while retrieving data from endpoint `/friends/ajax/superfriends.php?all...
Make sure you are connected to the internet and also try resfreshing the page. Let me know how this works.
Jun 22, 2009 | Facebook Social Network
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
MSI - 845GLMS (MS-6754) powers off
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=522
Link to board.
Manual: http://global.msi.com.tw/index.php?func=downloadfile&dno=3640&type=manual
This error message may occur if the primary disk group identity of the hard disk does not match the primary disk group identity that is stored in the registry. There wasn't anything wrong with your memory or PSU. (not the cause for blue screen).
If there is data on the primary drive than slave it into another system & copy the data to another drive or CD. The most common data to copy. My Documents, Favorits, Desktop. Users name(jeff), open Application Data, copy Identities. open Mocrosoft, copy Address Book.
What is needed is a fresh install of windows. You can either boot to windows through the cdrom & quick format before install or use the hard drive's utility disk software or CD/iso bootable's to redo the drive. I understand this is a replacement board & one would think that re-connecting everything the system should just boot but from time to time widows gets trashed in the prosses. Though the quick formatt is faster I prefer to use the Mfg's bootable ISO to make a bootable CD. Here you can also check the drive & MBR & pick size & even FAT type.
The choice's are up to you. Just make sure the bios is seeing the drive correctly.
Feb 18, 2008 | MSI 845GLMS-L (MS-6754G-020) Motherboard
T420 error lights
does this occur after while, during or after printing?
from what application are you printing?
sounds like the print you are sending may be too big for the memory of the printer, or it can not recognize the file type.
Oct 16, 2007 | Lexmark T420d Laser Printer
Intermec EasyCoder F4 Printer Logo
147 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
