Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Tv discoloration I have a hitachi 50V715 and the middle of the screen has this yellowish tint to it making whites look yellow but its just in the dead center everywhere else is fine the picture is still great just that one color issue any solutions?
  • Anonymous Aug 29, 2008
    I have the same problem except mine started out as a red blur. I replaced the lamp hoping that would clear it up, but it did not. Now not only do I have the red blur but the screen is also turning yellow.
  • Anonymous Sep 05, 2008
    recieved new(new ??) light engine for my hitachi 505000A. recently noticed a yellow spot about the size of a silver dollar. Is there more to come? Will keep an eye on it and this better be quaranteed for more than the usual thirty days. a new t.v. is quaranteed for a year. a new part should recieve a year as well.....unless its a rebuilt part.
  • 11 Answers
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
Hitachi 50v715 screen is yellow in the middle while the outer edges of the screen show white
The Optical Engine needs to be replaced. Due to the cost of the repair, I recommend you to call Hitachi at 1800-HITACHI to see if they could help with repairs and also refer a Service Facility to you to confirm the symptom.
I hope this helps,
Skyassoc
Oct 24, 2009 | Televison & Video
The whites are yellow and theres a yellow tint to the picture in general although not real bad. Is this just the lamp # ux21513 needing to be replaced? Thank You
The Lamp would cause the picture to be dimmer but not discolored. I would suspect the Optical Engine is causing the yellowish tint. Due to the cost of replacing, call Hitachi at
1800-448-2244 and see if they would be willing to help with the repair.
Hope this helps,
Skyassoc
Jul 18, 2009 | Hitachi 60V710 60" Rear Projection HDTV
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
May 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
Yellow hue circle in middle of screen. after leaving tv on all night
spherical or oval shaped light starting in the center of your picture is an indication of an led backlit tv.. probably a hitachi. solution, replace light engine..ps no garuntees not with led backlit sets.. was bad idea to begin with. when the leds start going they start at the center and branch out.
Apr 13, 2009 | Hitachi 50V715 50" Rear Projection...
Yellow discoloration on screen
the screen is yellow green color all the we have had it worked on once already does anyoblemne have any comments on how to solve this problems?
Jan 27, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
50V715 HITACHI -GREENISH TINT -
Solution for the Hitachi 50V715. I contacted Hitachi and they told me there is a problem with the color engine with this and other Hitachi models. They will replace the part for free, but first I need to take it to a repair shop to verify the problem and I have to pay labor. Not too bad considering the cost of the engine.
Dec 19, 2008 | Hitachi 60V715 60" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
322 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
