Question about Rinnai Heating & Cooling
Rinnai energysaver 556FTR filter light flashing
You need to remove the filter and vacuum it. Recommended cleaning once per week.
Posted on Jul 25, 2009
  • 639 Answers
Happy to assist you!
Perhaps a bad blower.
Sounds like an electronic failure!
words alone will not remedy the situation!
Do not wait to fix it next year!
The cost will be more then Bad Infaltion!!!!!!!!!
You need to call service !!!!!!!!!!!!!
Posted on Aug 29, 2008
  • Sarah Apr 11, 2016
    Hi there I have the same heater and I vaccum my heater inside atleast once a month and it continues. How can I stop it over heating ??
Can a Rinnai 556FTR (2010) flue be converted from straight out the wall - to out a chimney?
No, Rinnai manufacture other models with a conventional flue.
Most models these days are balanced flue for ease of installation.
Jan 07, 2014 | Rinnai Heating & Cooling
I have a rennai energysaver 556ftr heater, and the filter and on light keeps flashing red, i've taken out the filter and cleaned it, but still the lights are flashing. what's wrong?
If you removed the filter to clean it, while the unit was ON, that may be the problem. Turn the Master ON/OFF Switch to OFF and unplug the unit from wall outlet. Leave unplugged for 15 minutes. Remove and replace the filter. After 15 minutes has elapsed, plug the unit into the wall outlet and turn the Master ON/OFF Switch to ON. The unit should have reset itself and reverted back to the original factory default settings. In which case, you can change the settings to what you desire.
Just remember to always turn the Master ON/OFF Switch to OFF, when removing the filter to clean and replace it.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
Jul 27, 2010 | Panasonic Heating & Cooling
Fault 14 on rinnai energysaver 556ftr
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error code 11 on a Rinnai energysaver 556FTR
The 11 code means Missed Ignition. This is a broad error code. It just means the stove did not light when it was supposed to. I would check the fuel first to be sure the valve is on and you have gas. Next, try to start the stove with the room dark. Look into the window to confirm a sparking. This is the igniter. At the same time be sure the combustion motor is running. You should be able to hear it and feel the stove to confirm this. If the motor does not turn or the flue is blocked you will not get any gas to flow. Look outside to confirm the flue is not blocked.
Keep us posted,
May 29, 2010 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 556 ftr keeps flashing code 12
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Our heater 556ftr is got a code error flashing, 14
I found the manual on the net and it said error code 14 is overheating, it suggests to clean the filter, but my filter was clean, so I'm wondering if my flue has been installed incorrectly. On mine the error code is staying on after switching the power off and on, so this means my thermal fuse has blown.
Aug 08, 2008 | Rinnai Heating & Cooling
Heating & Cooling Logo
472 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
