Philips 26PF5520D/10 TV Now, after 2 perfect years,when switching on, the picture is fragmented into narrow horizontal bands which flicker up and down for occasionally only 8 minutes, but mostly 20 - 30 minutes before settling suddenly to clear picture. Clear non-geek advice appreciated. Nick
  • arosphoto Sep 01, 2008
    Thanks for suggestion which i will have checked by service engineer, nick
  • 4,234 Answers
This sounds more like a connection problem IF you can solder, try looking for any solder connections that appear grainy or have rings and resolder them. It is possible that there is a heat sensitive component as well, but lets start with the simple stuff first.
Keep us posted on your progress.
Dan
Posted on Aug 29, 2008
    Master:
  • 521 Answers
Problem with the ---ic--- on the circuit board.
  • tech expert12 Aug 29, 2008
    actually the ---ic-- gets heated up after 20-30 minites and then it works fine.get it repaired quickly as it indicates that the --ic-- on the board is at the end of its life.getting it repair will help to avoid further damage to your device.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
    it will not cost you much .will be under the service charge of the technician.so get it repaired soon.its a common problem .and also very minor.do not worry.
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
Mar 12, 2017 | Televison & Video
Picture flickers for 5-10 minutes then goes black
in the back of the t.v. there is a mother board. on the mother board ( im not sure what it is called so i will describe it)
it looks like a black tune. it has a red wire comeing out of he top going to the front of the t.v. connecting to the picture tubes. now see what happens is that tube will heat up and sometimes loose connection. what i found to be helpful is to stick a peice of cardnpard under it so it gets a good connection again. but do becarful because it is high voltage....... so if you decide to try to work on the t.v. please unplug it first.
Aug 07, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Horizontal problem
Hi
The narrow picture is often related with a dried reservoir capacitor, the big capacitor placed in power supply section. You can test connecting in parallel a good capacitor with the same capacitance and working voltage (generally 400VDC). You shoul take all precautions required on working with high voltage such as discharging capacitors before dessoldering anything from the board, not touching the "hot" parts, etc.
Sully
Jan 10, 2013 | Philips Magnavox 27MS343S 27" TV
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
I am unable to make the screen full size when the
you need to go into the settings on the box and turn off letterbox on the picture setting.
Mar 29, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
Rear projection TV (LG 44SZ51): Horizontal dark band on upper screen field
The LG 44SZ21RB Have a problem with their light tunnel collasping due to the heat from the lamp. They are available as a spare part @ LG and would also require some silicon adhesive to bond it into the assembly. Very tedious job for any technican (2-3 hrs). Lg will not release parts to the general public only to an authorised LG agent.
Mar 30, 2008 | LG RU-44SZ51D 44" Rear Projection...
Video keeps flickering
TRY SWITCHING VIDEO SYSTEM. PAL TO NTSC.
Jan 30, 2008 | Farenheit DVD-36 Car DVD Player
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
