Question about Whirlpool AWM8163 Front Load Washer
AWM 8163 Whirlpool washing machine
When my machine goes into the spin cycle it makes lots of noise along with vibration. If I push the left side of the door in it makes the machine run a lot quiter. I have replaced the motor and just recently I replaced the shock absorbers thinking that may cure the problem.
Just to let you know before the washer goes into spin cycle it seems to try and balance the load. It still does this but it is still noisy.
If I set the spin speed down to 1400 RPM or less then it is quiet.
I am thinking now it must be the main bearing as I can't see anything broken or loose.
Help please
Cheers
Pete
p40new@hotmail.com
  • Anonymous Feb 03, 2009
    My washing machine makes a noise when spinning. Turning the drum by hand I can hear a noise of metal scratching on metal at two points in one revolution. The drum is split into 3 sections or vanes. There is a slight scratch of metal on metal at 120degrees and 240degrees. After a spin one item in the washing comes out with oily spots (4 or 5) in a line separated by the distance between the holes in the drum. It looks like the piece of washing is picking up the debris from the obstruction during spin. The noise appears to be coming from the right hand centre where the outer drum is suspended on the shock absorber spring. I suspect the inner drum has a snag at two points. The bearing appears to be OK since I cannot manipulate the drum by hand to get rid of the scratching noise
  • Anonymous Mar 29, 2014
    think it is shock absorbers
  • 734 Answers
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Dec 12, 2008
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
Spinning cycle makes a lot of noise
See if the tub will spin freely by hand. Spin it both ways. It should coast silently to a stop. If you hear a dragging sound or it doesn't spin smoothly look for a sock between the inner and outer tubs. Start looking in the upper left side at about the 10:00 and 11:00 positions. That's where i usually find them.
If it seems to spin ok then see if the inner tub wobbles separately from the outer drum. Push up on inner basket from inside. The outer drum and inner tub should rise and fall as a solid piece. If you feel a separation the bearings need replaced or the spider assembly has broken. Only a complete teardown can tell which. Hope this helps.
Jan 27, 2013 | Whirlpool Duet GHW9150P Front Load Washer
We just had a new top-load Maytag Washer delivered. When the man finished installing it, he started a wash cycle and left. When it got to the spin cycle there was a lot of vibration. It doesn't...
NO. Have you checked if he installed an anti vibration pads. This is because the high frequency vibrations caused by the spin cycle can cause annoying noise and very serious long term structural damage to you home.
Jan 12, 2011 | Maytag Bravos MTW6600T Top Load Washer
WHirlpool 1600 Washing Machine AWM 8163 model. The letter ''P'' appears on the display screen and the washing cycle will not complete. Tried the other cycle and unfortanetly the motor sounds but the...
Removed the top cover of the machine and cleared out the hoses and the plastci chamber, which was full of limescale which had built up and also unscrewed the front outlet cover, again that had become clogged up with alsorts debris. Now it works a treat.
Dec 12, 2009 | Whirlpool Washing Machines
My Whirlpool AWM 8163 is flashing FP (orPF). Anybody have any ideas? Many thanks
You need to clean your filter once you have drained the water out look in the hole you will see a little impellor there might be an object loged in
Sep 16, 2009 | Whirlpool AWM8163 Front Load Washer
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
FAULT CODE F11
F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
Feb 08, 2009 | Whirlpool AWM8143 Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool AWM8163 Front Load Washer Logo
440 people viewed this question
Dan Webster
Dan Webster
Sal De
