Question about Canon CLC 1150 Color Copier
ERROR CODE at power on machine CANON COLOR LASER COPIER displays ERROR 0008
  • Anonymous Jan 20, 2009
    Canon CLC 1150
    The power shut down when I turn on
    on the top code is 0008
    on the bottom code is 0000
    Please help
  • Donna Allman Jan 25, 2013
    I am also having this exact error code. Does the oil need to be added?
    Problem Solver:
  • 5 Answers
Replace SW3 ( (TRANSFER. FRAME LEVER SWITCH) THE PROBLEM E008 IS OIL AND NOT TERMISTOR OR THERMOFUSE
Posted on Nov 24, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
There is a problem with the fuser, replace thermistor or thermofuse
Posted on Aug 29, 2008
Canon ir c3220 color copier error E000020-01b0. What means? How solve that error?
Canon Error Code E000020 01b0
Although the yellow drum is indicated, in the link above, please note it may not be the yellow drum if instead it is the:"laser shutter or the plastic actuator on the right side of the front door."
Jan 24, 2018 | Office Equipment & Supplies
Error
Turn the Main power switch off then back on. If you want a better answer try to let us know what the error code that is displayed on the display. There are ruffly about 100 or so error code. Good Luck
Jun 16, 2012 | Canon imageRUNNER C5180i Color Copier
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
CLC 1180 gives the error code E804 000B and instructs me to turn the unit off and on again. Once this step is completed, it reoccurs.
E804 0006 The laser scanner motor
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
Oct 19, 2009 | Canon CLC 1150 Color Copier
I own a Canon Laser Color Copier Model No. 1150 CLC1150. The error code when I start up the copier is E0000 0132. How can I fix this issue?
E0000-0132
the cause of error is the fixing heater/s is not functioning well .Try this press asterisk with the head then 2 and 8 simultaneously then same asterisk with head. The lcd display will change Pres the ff: COPIER>Function>Clear>Err > ok .to reset fixing error .Switch power off and on the machine.If the Error
return, you have to call the canon service agent to check your fixing/fusing unit and its components
regards
Jun 21, 2009 | Canon CLC 1150 Color Copier
Error E078 Canon MF8180c
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Jun 05, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Jun 03, 2009 | Canon imageRUNNER 400S Copier
Canon IR 3380i Error code#E000674-0008
fax board communication error try turning off copier then unplug it for 5 min turn on if code comes back it designates a problem with your fax board.
Jan 27, 2009 | Canon C3380i Color Copier
Canon 8180C laser Multi Function printer Error Code 078
did you reset the drum unit on maintanance counter of the machine?
Apr 18, 2008 | Canon MF8180C Color Copier
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Canon CLC 1150 Color Copier Logo
199 people viewed this question
old marine
old marine
