Question about Acer Aspire 5610-4648 Notebook
Wi fi problem
I have tried what u have told to me but it is also not working so what should i do. please give me some more advise.
  • danman1453 May 11, 2010
    what did you try? what is wrong?
    Problem Solver:
  • 50 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
15
Posted on Jul 25, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Trying to connect tablet to wifi saying its not in range but laptop and cell phones are connected was told need a booster
Could be no available connection on the radio wi fi system you may have reached maximum user capacity try turning off wi fi on one of the currently connected devices and see if tablet connects to it . Was it 802.11G the Wi fi system.
Dec 11, 2014 | Hipstreet Hip Street Titan2 HS-7DTB25-BND7...
I am trying to do the wifi protected setup with the 8 digit pin it gives me, I get the pin press the wifi ps button, it fails everytime. what are the correct steps to take please help. Alcatel One Touch...
What is giving you the 8 digit pin is it coming from the wireless router or wireless network provider ?
on your phone
To turn Wi-Fi on and connect to a wireless network
Drag down notification panel and touch
to access
Settings
Touch the switch
beside Wi-Fi to turn on/off Wi-Fi.
Touch
Wi-Fi
, the detailed information of detected Wi-Fi networks is displayed in the Wi-Fi
networks section.
Touch a Wi-Fi network to connect. If the network you selected is secured, you are required to enter
a password or other credentials (you may contact your network operator for details). When finished,
touch
Connect
Nov 02, 2014 | Computers & Internet
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Loss of Wi-fi
Have a Inspiron Mini 10 Model P19S belonged to my sons girlfriend .. they broke up and she told him to keep it..when i turn it on it show password, but she refuses to give me the password. I tried the F8 to return to safe mode. This don't work. I would like to access the computer to use it, but seems nothing is working. I don't have money to take it to a computer expert. Can you give me any assistance please. I would appreciate any help.
Jan 25, 2014 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Wi Fi network Toggle Not Working
They usually slide very easily. Have you tried moving the toggle with the laptop open? And have you tried it with the laptop closed?
Nov 30, 2013 | Nextbook Premium 8 Se Android
Neighbors hve wifi but wont give me the code. Is there a code that i can use to gwt pass it.
No there is only the password they set. I advise getting your own wi fi because they are paying for theirs and they dont want to give it away for free. Plus that is illegal if you break into their wi fi. Sorry but you will have to get your own wi fi.
May 07, 2011 | Sony Playstation 3 (PS3) Console
Xv6700 phone won't make calls "a wireless radio must be attached"
I HAVE THE OPPOSITE PROBLEM, I WANT WI FI TO WORK WITH OUT PHONE SERVICE ACTIVATED. IS THIS POSSIBLE?????
Jul 23, 2010 | Audiovox XV6700
Acer Aspire 5610-4648 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
