Question about Motorola Mobility Bluetooth Headset H3 for Razr Headset
Setting up my blue tooth
I just brought a universal bluetooth headset H375 for my razor phone and it did not come with instructions. I charged it already but it is not allow me to connect.
  • 2,322 Answers
Here are the instructions to operate your bluetooth.
Posted on Aug 29, 2008
    Problem Solver:
  • 39 Answers
Hey,
For connection of the headset, First switch on the headset(the blue tooth button of the headset) now in your mobile phone check the blue tooth devices and check if the universal bluetooth headset comes on the screen
Select the bluetooth device and we are on..
Cheers
Kushal Agarwal
  • Kushal Agarwal Aug 29, 2008
    omg so many ppl so fast !
    President:
  • 2,961 Answers
Press the side button for 3 secs until it lights up solid and then go to your phone, search bluetooth devices until the headset shows, enter 0000 as the passkey, the light will then flash intermittently telling you that its connected
  • 19,396 Answers
You need to pair it with the phone, working on phone settings, what is phone model?
  • Ginko
    Ginko Aug 29, 2008
    First you need to set the headset on pairing mode. To set the headset on pairing mode you need to push and hold down the call button for about ten seconds.
    The
    blue light should turn on and stay on, when light is flashing the headset is not in pairing mode
    Now, here follow the general procedure for Moto
    you should go to
    Menu
    Settings
    Connections
    Bluetooth.
    Now select the "Handsfree" option and your phone will start looking for the headset
    Now chose "Look for Devices" option and the phone will scan for devices and find the headset
    To proceed, just select the headset.
  • Ginko
    Ginko Aug 29, 2008
    Additionally, here is Z375 quickstart guide:
    BEFORE YOU BEGIN ... BLUETOOTH FEATURE
    And here is explained how to pair a moto on z6w guide:
    get started get started get started
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
What is the passcode
pass code is just like a password required to pair any two devices.... in this instance i guess, you mean the passcode for your motorolla blue tooth head set, this needs to key in passcode which you have for your mobile
Nov 25, 2009 | Motorola Mobility H375 Bluetooth Headset
Bluetooth
Here's the user manual online.
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H375%20Bluetooth%20Headset%20QSG.pdf
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Blue tooth headset for nokia 3110c
You can purchase a universal bluetooth headset and then pair the device using the instruction manual that comes with the headset. This is a very easy process and all you need to do is make sure that the blutooth on your phone is switched on. When you turn the headset on, it should automatically pair after the first attempt.
Jun 07, 2008 | Nokia 3110 Cellular Phone
H375 bluetooth
Your default passcode is 1234 or 0000 so try this and tell me if it works.
please rate me. thank you.
May 30, 2008 | Motorola Mobility RAZR V3
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Open Questions:
Motorola Mobility Bluetooth Headset H3 for Razr Headset Logo
212 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
