Question about Gateway GT4016 Desktop PC
BIOS defaults despite new Battery
I am loosing time and BIOS defaults when the Computer is Unplugged from AC. I have replace the mother board battery but the problem persists. There is a 3 point pin header near the battery. A jumper links two pins. Perhaps it is in the wrong place. What is the correct place and what else can I check?
Thank you,
navdonin@hotmail.com
    President:
  • 2,961 Answers
Unless you have cleared the cmos the jumpers should be in the right place, but check the JBAT1 or CLRMOS or CLRCLK, depending on mobo, if tey are over pins 1 and 2 move to 3 and 4 or visa versa
Posted on Aug 29, 2008
Reset password
All mother board has a CMOS, complementary metal oxide semiconductor, battery. The main purpose for the CMOS battery is to store the system time, date and bios settings even if the computer is turned off or the main battery dies.
Turn off the computer (laptop) unplug it. Remove the Phillips screws that secure the motherboard cover then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. After a few minutes plug the CMOS battery into the motherboard... Replace the screws then turn the computer (laptop) back over. The CMOS battery is unplugged for more than a few minutes your BIOS will be reset to the default manufacturer settings.
Apr 20, 2011 | Computers & Internet
How to chang bios settings password intel Dg43nb board i m loss my bios password
Turn off the computer (laptop) unplug it. Remove the Phillips screws that secure the motherboard cover then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. After a few minutes plug the CMOS battery into the motherboard... Replace the screws then turn the computer (laptop) back over. The CMOS battery is unplugged for more than a few minutes your BIOS will be reset to the default manufacturer settings. (Password removed) now you can set new password for your bios..
Apr 20, 2011 | Office Equipment & Supplies
How can i remove password from my loptop?
Apr 18, 2011 | Gateway CX2610 Notebook
Can you turn off the password on the motherboard
The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box (Make sure you have your manual handy), LOCATE THE CMOS BATTERY (it is look like a silver Small coin) take out the CMOS battery from the main board ( note: Before taking out the battery make sure that you already touch metal object to remove static electricity) . Then once you take out that the bios password will be reset to blank. Put it back after a few minutes. Same process as what you did when you take it out. Hope this help. Good Luck
Apr 16, 2011 | Dell (E210882) Motherboard
I have a Dell Latitude D610. The battery was dead (got the 4 blinking amber lights and the green light flashing once, then cycling), so I replaced the battery. The new battery has the lights on the bottom...
From the description, sounds like you have two failures, both concerning the mother board.
1. The connection to the motherboard for the battery is no longer good. Replace the mother board. The points of failure that you have given so far and has not fixed the issue. Battery fully charged, seated well, no change, mother board.
2. Laptop will come on with AC adapter attached but will not boot up; mother board. There is a built in test that you can run, from a powered down state press FN + Power button, this puts this into a diagnostic state. If it does not go into this diagnostic; mother board. The diagnostic is stored in the BIOS, which is a part of the mother board.
3. If the diagnostic runs note any error codes that it gives. They will be in the form off XXXX-XXXX or XXXX:XXXX, where the X's represent a letter or a number. These can be used for further trouble shooting.
Jul 24, 2010 | Dell Latitude D610 Notebook
Bios date is not being saved
it has to be the battery contacts, the motherboard is loosing contact with the battery which is why it keeps resetting itself
Jul 06, 2010 | Computers & Internet
What is optiplex gx 260 pc's default bios password?my pc ask a bios password,but i never enable bios password.
Here are some important links from which you can get the easy steps and your solution.So please visit the below links and I am sure your problem will be solved
http://www.computerhope.com/issues/ch000235.htm
http://www.computerhope.com/issues/ch000451.htm
http://www.dewassoc.com/support/bios/bios_password.htm
Please rate me if this solution works for you
Thanks......Have a great time
Jun 28, 2010 | Dell OptiPlex GX260 PC Desktop
Pc starting problem
There is a battery on you motherboard and it needs to be replaced. Usually it's a large round lithium battery. If you replace that it should go to default.
Mar 10, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Battery charging problem HP DB6000 series
They either didn't replace MB or didn't replace charging IC on MB. Needs to be done either.
Jan 04, 2009 | HP Pavilion dv6000z Notebook
Gateway GT4016 Desktop PC Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
