Question about HP iPAQ RX3115 Pocket PC
IPAQ RX3115 Crash
I bought a RX3115 yesterday and it works great until it powers down by itself. Once this happens I am unable to turn it on. The only way I can get it to respond is to hard reset the device which dumps all data. I have tried 5 times with the same result.
    Master:
  • 450 Answers
I contacted HP on-line chat and after doing a few tests they advised me to exchange it for another one with the dealer. My second one is working great. I think it might be a Li-Poly battery issue as I deal with similar issues in my business using them.
Posted on Sep 11, 2005
I want to restart of shut down my HP iPAQ rx3115
For the HP iPAQ rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Mar 01, 2011 | Cell Phones
Is the Ipaq RX3115 compatible with Windows Vista?
Yes, but you will need to download Windows Mobile Device Center - free from Microsoft,
which replaces ActiveSync
ActiveSync is not compatible with Vista
Oct 22, 2008 | HP iPAQ RX3115 Pocket PC
IPAQ rx3115 continuously, "screen alignment",
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3115 (or RX3715) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
Feb 26, 2008 | HP iPAQ RX3115 Pocket PC
IPaq rx3115
I had a similar experience. My device would not charge via the usb charger so I connected it to my wall charger and it charged successfully.
Jul 07, 2007 | HP iPAQ RX3115 Pocket PC
HP iPaq Rx3115 ...Please Help..
It depends what quality you need. If you need top quality you will have to go for something else like a dell axim x50v. This PDA should be ok for watching a movie as long as it is encoded properly, at a low resolution that is.
Sep 15, 2005 | HP iPAQ RX3115 Pocket PC
Lost sound
So there's another icon at top of Today screen - a loudspeaker icon - tap on that and make sure it's not muted or all the way down.
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
Rx3115 won't show close button
Jul 14, 2005 18:26:04 GMT unassigned Well, this isn't a solution, but rather a way to work with it until you find the solution. On my rx3715, I have something called iTask. I have a button I can press on the unit that brings it up, or I can go to Programs and tap on iTask. Once it's up, I can see which programs are running and close one or all of them. Another way, if you don't have iTask or something like it, is to use your memory settings to close programs. On mine, I go to Settings>Memory and then the Running Programs tab. From there I can "stop" any program. I know this doesn't solve the problem, but now at least you'll be able to close all those programs. For a solution, I'd try doing a soft reset. If that doesn't work, do a hard reset. Maybe someone else will have some better ideas.
How do i uninstall programs?
Go to Start > Settings > System > Remove Programs
Sep 11, 2005 | HP iPAQ RX3115 Pocket PC
RX3115 Remains on
Calendar appointments will wake up the unit. You can change the power settings so that the unit will turn off after a certain amount of time. On my iPAQ rx3715, it's Start>Settings>Power>Advanced tab.
IPAQ rx3115 would not bypass the screen aligning
I experienced the same problem with my rx3115 after having it for 3 days. It is working again, fortunately. I removed the battery from the device and left it alone for 24 hours. I then reinstalled the battery and connected the charger. When it powered up, it went through the initialization process in the same way that it did when I first used it. I hope this helps you out with your iPAQ.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
