Question about HP iPAQ HX2755 Pocket PC
Connection problem Hi, I recently bought a hx2755 PDA but have connection problem. I connected it through USB connection. It worked for a few times (sparsely) but most of the time it could not get connected. I have no idea why it is that. Is that the problem of the PDA, or cadle, or my computer setting? I have tried many ways to solve it - uninstall and re-install the Activesync, reboot the computer, turn on and off the PDA, etc, but it still did not work. Can anybody help me to figure out the problem please? Thanks.
    Master:
  • 450 Answers
Have you considered software running in the background on your computer? Usually firewall/anti-virus software can block the connection. If you are running any Norton or McAfee products, it is likely the cause. Try disabling them, or boot into safe mode with networking support and see if the PDA responds from here. Safe mode loads a minimal set of drivers and no startup programs. Goodluck!
Posted on Sep 11, 2005
I recently lost my USB Connection for this and I bought a new USB Connection for it , but now when I connect my camera into my Computers USB slot It doesn't recognize it.
Try with other USB ports in computer . If it works then it is fine . Else the cable which you got one is faulty ,you need to replace it .
Hope this helps .
Mar 20, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Cannot connect my PDA to PC
Normally for when you connect any device to pc using USB port, windows detects it. Sometime it may take time.
Few initial things you may check....
1) You must have your PDA in ON condition
2) If PDA is not getting connected on port, try connecting to other USB port (assuming that pc normally have more than one USB port)
3) Make sure the cable that you are using between PDA to PC is working properly (normally you can check this by using other cable)
4) If you have intalled some anti virus program on your pc then check the settings of same.
5) last but not least check the settings of window's firewall (part of OS)
If everything of above is fine then either USB ports of pc or of PDA might not be working.
All the best!!
Regards,
Av
Dec 10, 2008 | Computers & Internet
HP Ipaq h5550 does not connect through cradle
First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
Jun 30, 2008 | HP iPAQ H5550 Pocket PC
Acer n300 wont sync
you also have a connection manager on the PDA Itself ( Active sync ) Try syncing from the PDA as Well As The Computer Active Sync Program.
Also make sure if you have a firewall, you allow the PDA into it as a trusted Device.
Mike @ Compurepair.
1 more thing, try on/off the PDA whilst in sync mode.
Hope This Helps.
Feb 21, 2008 | Acer N300 Pocket PC
PC/PDA "connected" yet PC won't read PDA
try syncing through bluetooth, there could be a problem with the cradle. i have had an issue very similar to yours and had to do a soft reset on my pda. then set up your device to use a blue tooth connection( you may need to buy a bluetooth dongle for your pc).
Feb 06, 2008 | Compaq iPAQ H3850 Pocket PC
Can not connect my PDA
Hi __Try to Uninstall the toshiba software. Also search for the Folder called Toshiba and remove that as well.____Then Re-Boot Your machine. ____Re-Install the Toshiba software and that should work.____If not we can do a live meeting and I can help you troubleshoot the problem.____VR____JustAskMe
May 04, 2007 | Toshiba e405 Pocket PC
Connecting Axim plus Palm on the Same PC
I may be wrong but each PDA (assuming you are connecting different brands) have different drivers. I connected a Toshiba and Dell PDA and each required their respective install disk with their respective drivers. Then I configured each pda using the Active Sync Connection Wizard. Everything ran smoothly after that.
Sep 14, 2005 | Dell Axim X3 Pocket PC
Bluetooth Problems with HX2755
As an update I have contacted hp Warranty Support via phone and we determined that all the criteria was made to have the hx2755 returned to have diagnostics performed and repair if needed.. All my computers and periphery are HP as I have full confidence in the product line.
Sep 14, 2005 | HP iPAQ HX2755 Pocket PC
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Problem serial connection e400 using cradle
I am not 100% sure if I am correct in this, but I am quite sure that the e400 does not support a serial connection. Only the e800 does.
Sep 11, 2005 | Toshiba e400 Pocket PC
HP iPAQ HX2755 Pocket PC Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
