Question about Nintendo Wii Console
Power led light
The power led lighton the wii fit board does not stay on when seting it.
  • 1 more comment
  • bqpmcap78 Sep 25, 2008
    The power on light on the Wii fit board does not come on. I have replaced the batteries. I have tried the resynch button. It worked fine the day before and now nothing.
  • Anonymous Sep 29, 2008
    I have the same problem with my Wii Fit board. I cannot get it to power on. It has new batteries (tried 2 sets) and will sync (red light flashes for some time) but then nothing. Cannot get it to power on. Help!
  • dln_4u Jan 11, 2009
    It was working for almost 2 weeks then all of the sudden when I turn the board on, the blue light flashes then turns itself off. I have changed the batteries, re-synced everything. Nothing helps. It was not abused in any way. Just one day decided to not work. :-(
    Problem Solver:
  • 16 Answers
If there is no reason for the Wii Balance Board to be on, it will automatically turn off. Start up a game that uses the Balance (Wii Fit) and it will tell you when to turn on the Wii Balance Board. If you still have problems, try to sync the Balance Board again.
Posted on Sep 01, 2008
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
I have a wii fit board, when you power it up, it
Had the same problem. It's a sync problem.
First, best to double check you have fresh batteries.
Next, turn the board upside down and remove the cover from the battery compartment.
Open the small hatch cover on the front of your console unit.
Now start wii fit from the disk menu item.
Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
While they are blinking, press the red button on the console (in the hatch compartment).
This should re-sync your board and the light stays lit.
Good luck.
Apr 07, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
My wii fit board keeps telling me to ''step off the balance board and press A'' I am not standing on it when i get this message. I've checked the batteries, re synched the board to my wii, taken out the...
Looked around for a solution for a long time for this one.
1) removing the batteries from the Wii Fit balance board for at least a minute.
2) Turn the Wii OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds plug the cord back into the outlet.
2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This should clear all the old syncs on the Wii.
3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
a With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will turn on.
c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console.
d When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
4 Start the game from the Wii Menu, don't forget to sync the Wii Balance Board from the opening screen of the game (you've deleted the syncs earlier).
Another problem may be the surface on which you post the Wii fit, make sure it's flat, try put it on the floor directly or place it on a rug.
And don't forget to "step on" it when it says and not before as the Wii console might be "overloaded".
Jan 31, 2010 | Nintendo Wii Fit for Wii
My wii fit board's power LED flashs for seconds then goes off and it keep asking me to switch it on before stepping on
The wii fit board acts the same way as the wii controller. You have to sync the wii fit board to the console.
Dec 14, 2009 | Nintendo Wii Console
Wii fit board won't work
Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
The exact procedure is:
• Even if the battery level is strong, try the following:
Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
Try these steps!
1 Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
Hope it helped.
Nov 24, 2009 | Nintendo Wii Fit - Balance Board + Game...
I can't set up my wii fit. When you hit the sync button the LED power never stays on on the board. HELP!
Try first press and hold the red SYNC button on the Wii console (open the SD Card slot cover on the front of the Wii console, the button is just below the disc drive) for 15 seconds. This will clear all synced Wii things from the console.Now sync all back.Push the red sync button on the console, then open the batteries cover on your Wii Remote and push the red button there.Then sync also Wii fit.
Nov 24, 2009 | Nintendo Video Game Consoles & Games
Balance board on wii fit doesn't turn on? power light flashes
All i had to do was SYNCHRO the board by pressing the synchro button on the wii balance board were the battries go, the power LED will blink (note once the power LED has started blinking, stop pressing the synchro button)
THen you need to press the synchro button on the wii console, while the wii balance board's power LED is blinking
Oct 17, 2009 | Nintendo Video Game Consoles & Games
Nintendo Wii Console Logo
274 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
