FixYa.com
Tags:
Toshiba PDR-3330 Digital Camera
Card Error
posted by Guest on Sep 11, 2005
If have a warning message "CARD ERROR" in the LCD Display. what shuold I do?
Solution #1
posted on Sep 11, 2005
Not Rated (0)
Adig
Adig - usenet poster
Rank:Wiz Wiz
Rating: 82%, 18 votes
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following:
Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary.
Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position.
If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased.
Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Digital Cameras problems?
Digital Cameras
cannot set tome on my
cannot set tome on my new nikon... Answer This...
PNY 2GB memory card
Can the Toshiba PDR-3330 take... Answer This...
comes on, beeps 3 times and...
I have put in newly charged... Answer This...
SD Memory card
Does anyone know why the memory... Answer This...
instalisation
can you sajust me how &... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
