Question about Canon PIXMA iX4000 InkJet Photo Printer
IX4000. Message: WASTE TANK ALMOST FULL
Good morning,
iX4000.   Message: WASTE TANK ALMOST FULL.
Where do I find the instructions as to how to empty/replace the WASTE TANK and reset the indicator?  Anybody know?  I looked on this forum but did not find any instructions for the iX4000.
Especially resetting the machine is important as getting to the tank/pad is probably easy.
Thank you.
  • ChangeAgent Sep 23, 2008
    Anybody any idea?
  • Anonymous Dec 15, 2008
    mine is Full already i still dont know where is the wast tank!!!
Blinking 15x
Posted on Mar 07, 2009
I have a Canon iX4000 color printer which is now showing a Error 5C00\r\nplease help
Your 'waste ink tank' is supposedly getting full.
Note that it may actually be getting full, if it is, and you keep printing, it can get messy. very very messy. ;>
I'd use a piece of folded newspaper about the size of the printer underneath the printer just to be safe. If you do this waste tank counter reset a few times, you WILL leak ink.
Power off the printer. Hold down Resume button, keep holding.
Hold down power button, wait for beep, release resume button while still holding power button down.
Press Resume twice, and release all buttons. Wait for indicator light to settle (stop changing). Press resume either 3 or 4 times, the indicator light will turn orange when you have pressed it enough times. Do not hold, just press.
When the light is orange, press power.
If you still get the error, you may have enough ink to actually physically block a sensor in the tank. When that happens, not only are you close to ink stains, you have to disassemble the printer and clean the pads and 'tank' out. This is even messier than an ink leak. ;>
Sep 08, 2010 | Canon PIXMA iX4000 InkJet Photo Printer
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Where is a waste ink i have error message says WASTE INK NEAR FULL help me on that, thanks
I have had this problem. There is a counter in your printer that must be reset to move on. The ink tank may not be full, but the counter estimates it is full (and maybe it is an instruction to you to buy a new Canon printer), and to actually empty the ink tank would be an uneconomical task. How do you do it, there are a number of helpers here so Google: MP730 waste ink near full.
Apr 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Signal waste inkt is full
Hello hope this will do the trick for you
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 15, 2008 | Canon SmartBase MP730 All-In-One InkJet...
IX4000. Resetting a Canon iX4000. What is the button combination?
orange light keep on blinking no error message promted on computer
Sep 08, 2008 | Canon PIXMA iX4000 InkJet Photo Printer
I get an error message on Canon i960 printer that tells me the waste ink tank full. How can I empty this myself?
Read it all here.
Scroll about half the page, to:
WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEMThere is explained how to get rid of the error message very easy, and how to clean the waste ink pad manually. The latter seems not to be necessary, though.
Mar 27, 2008 | Computers & Internet
Error Message--Waste Toner Tank Full/Not Install
What I have started to do is to actually wash the toner tank out with water and make sure it is good and dry then be sure the section that breaks the light sensor is good and clean (it is on the left side as you look at the backside - the side that goes toward the printer - and protrudes out) the tank full indication comes on when the tank gets dirty
Jan 03, 2007 | Samsung CLP-550N Laser Printer
Canon PIXMA iX4000 InkJet Photo Printer Logo
1,073 people viewed this question
old marine
old marine
