Question about Neff K5624X0 1GB Refrigerator
Re Neff fridge of fridge freezer - water filling up at bottom all the time
My fridge/freezer is K9625X0GB/31 - about 6 years old, not hardly used. Previous owner of the property has not left handbook. Top fridge keeps having water residue at bottom - and worried that leaving it two weeks will result in flooding.
Richie_asg1
  • 1036 Answers
SOURCE: I have a 1996 Neff
Flexible PVC equipment wire or strimmer cord works.
Or something like a turkey baster- with plasticine to seal usually does the trick.
When clear, spray with a household cleaner to prevent mould growth.
Hope this provides a solution for you.
Posted on Jul 01, 2008
  • 1462 Answers
SOURCE: I have a Neff fridge
push something flexible down drain or put a small tube into drain hole and blow
Posted on Jul 02, 2008
landsend
  • 1066 Answers
SOURCE: neff american fridge freezer simply wont get cold
the advice you received was correct.
Posted on Mar 24, 2009
SOURCE: i have a large Neff refrigerator with a small
Hello Paul,
Try looking on ebay for a second hand or spares repair model.
Also try some of the refurb places where the cosmetic returns get sent with minor damage or faulty components.
PS:any chance you have fitting instructions for an integrated K4664 model ?
Mine came with no instructions how to reverse the door and fit to the wooden kitchen doors so and cant find any on the Neff website.
Thanks
I
PS:
Posted on Apr 10, 2009
  • 5 Answers
SOURCE: Neff K9724 Fridge Freezer with water in the fridge drawers
sounds like a thermastat problem or maybe your drain away hole is blocked
Posted on Apr 25, 2009
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
"Hi I have a NEFF built in fridge freezer 50/50.
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Oct 01, 2011 | Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
I have water accumulating in the bottom of my fridge, what can I do to stop this?
It is where the freezer defrosts and melts the ice. There is a small drain hole in bottom of fridge or freezer. use a vacuum cleaner and **** out trash. prob lint blown in by fan. clean all dust under it whill at it.
Aug 15, 2010 | Neff K9525X4
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Why is water is pooling at bottom of the fridge
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home.
Jan 05, 2010 | Fisher and Paykel Refrigerators
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Neff K5624X0 1GB Refrigerator Logo
108 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
