Epson Service D68 reset
Do you have the reset details for the D68 printer with a Mac?
  • Cathy G Oct 27, 2008
    I run an Epson D68 printer off my iMac which now won't print as it says it needs a service !  How do I get it going again.  It has been printing fine until now so this service thing seems a bit of a con !
    Thanks
    CathyG
How to reset epson d68
Posted on Jan 13, 2010
Epson D68 does not print anymore. it says that some parts need a maintenance service. How can I reset the counter? I am using a mac mini.
If it says that parts need maintenance its will probably be your waste ink pads are full You are supposed to take the printer to your nearest Epson service station to have it diagnosed the waste pads changed and the printer reset The usual cost for this is about £50 -£60 Or you could try to do the job yourself You need a service manual for your make of printer a set of ink pads and the ssc reset utility or you could take the pads out wash and dry them and reuse them Look up the net for the reset utility for your printer
Mar 30, 2010 | Epson Stylus C86 InkJet Printer
Both ink and paper light are flashing alternate and I cant get the printer to work epson d68
Your printer needs to be reset. Flashing lights means that your waste ink pad is full when that happens printer stops working to prevent flooding of waste ink inside your printer. Google search for a resetter program for epson d68. You need to replace the waste ink pad or create a tube line to divert the waste ink out of the printer. Good luck.
Jan 11, 2010 | Epson Office Equipment & Supplies
Epson D68 2 red lights flashing, the green light is not on and the printer seems dead
Fix it with this....http://www.refillingcartridge.com/reset-protection-counter-for-epson-c67-c68-and-d68
Nov 07, 2009 | Epson Office Equipment & Supplies
Epson D68 red light on constantly, checked the ink cartridges, then had 2 red flashing lights now back to one
Remove and reinsert the cartridges - the cartridge lid may be open.
Also, the printer may need to be reset. From:
http://ribensan.free.fr/
Select the Epson resetter, Save, unzip and run.
Hope this helps.
Sep 08, 2009 | Epson Office Equipment & Supplies
Lost my insruction manual for the EPSON STYLUS D68
The documentation for your printer is located HERE.
Mar 10, 2009 | Office Equipment & Supplies
How to reset manualy the counter on epson d68
Manual instruction Resetter Printer Epson D68
  1. Switch on printer
  2. Open auto.bat to set the date to 19 June 2006
  3. Run adjprog.exe from the extracted folder
  4. Click accept
  5. Click particular adjustment mode
  6. Go to maintenance then Select waste ink pad counter then click ok
  7. Click on “check button till its done then click on initialization button then click on finish button
  8. witch off printer for 5 secs then switch on again
  9. After you reset succesfully, you can change the date back to normal.
Please rate my solution after reading. Thank you
Mar 05, 2009 | Epson RX620 All-In-One InkJet Photo...
Epsom printer d68
The message means the waste ink pads are full and the internal counter in the printer needs to be reset.
you can take the machine to an Epson Express center who should be able to reset the counter in about 30 seconds. Changing the pads is a bigger job, but if this is the first time the machine has been reset you can probably skip the pad change and just go for the reset.
You could make a modification to the printer to use an external waste tank instead of the pads. Then whenever it reaches the limit again, you can just reset it.
Please rate this post as fixya.
Jul 16, 2008 | Epson Stylus C66 Photo InkJet Printer
D68 epson printer,both red lights flashing alternately.
Fix with this....http://www.refillingcartridge.com/reset-protection-counter-for-epson-c67-c68-and-d68
Jul 14, 2008 | Televison & Video
Epson D68 Printer
You will have to download the reset software. Check out this link:
http://www.ssclg.com/epsone.shtml
It is free and people have reported success with it.
Jan 28, 2008 | Office Equipment & Supplies
699 people viewed this question
jasbo
jasbo
