I have an orion TV19pl120 with build in DVD, i have it connected to my pc and also have a aerial picking up freeview. Twice now the tv has just lost connection with the pc and all stations, i have to turn everything off for 30 seconds and re-boot and then it works again. I am a little worried as my warranty runs out in 2 months, should i call the helpline from where i purchased the tv ? many thanks
  • 5 Answers
SOURCE: rolling picture
If your Television is not warrantied, there should be rca, vga, and dvi connections you can use with your pc and video card. Since I am in usa I have know idea what freeview, skybox, or scart are.
Posted on Dec 15, 2006
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
billyjones69
  • 42 Answers
SOURCE: TELEVISION
This user manual should help!
http://portablemedia.manualsonline.com/manuals/mfg/wharfedale_international/l15t11wa_l15t11wc_l19t11wa_l19t11wc_l20t11wa_l20t11wc_l19t12wa_l19t12wc_l20t12wa_l20t12wc_l22t11wa_l22t11wc.html
Posted on Jan 14, 2008
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Posted on Sep 28, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I can't record digital tv on the dvd recorder coupled with a new philips tv with built in digital
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Jun 27, 2011 | Mico DVDR311
I cannot connect the dvd, freeview and tv wires so that they all work. I only have one scart socket at the back of the tv but have bought a scart adaptor to solve this problem. I cannot get my dvd to work...
If your freeview has two scart sockets,connect a scart from the freeview(marked tv)into the tv,then one from the dvd into the other scart socket on the freeview,the main aerial should go into the freeview and a flylead out into the tv.Hope this helps
Sep 11, 2009 | Sony DVP-NS50P DVD Player
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
No aeriel just cable tv and dvd recorder
Hi,you will need an aerial for the dvd to pick up any analog signals or freeview,but if you connect a scart lead from you cable into you dvd on av2,you will be able to record cable.You will not be able to change chans when you are recording this way.It would be best to get an aerial and a freveiw box with a hard drive.Hope this is of some help? jamie
Mar 15, 2009 | Philips Televison & Video
I want to add a DVD recorder into my TV set up
If I'm right On the DVD recorder there should be an aerial input and an output. Connect external aerial to the output then run a second from the output to the TV. Then use the HDMI to connect the DVD. This will then give you the option of recording one channel on the DVD whilst watching another thru the receiver thats built into the TV. You will then get the best poss picture when viewing DVD
Nov 25, 2008 | Televison & Video
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
Jun 09, 2008 | Philips Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
