After cleaning my toshiba satellite pro and re-install of everything, my usb 2.0 ports are acting as usb 1 ports. The said laptop is an offline computer for audio purposes only.
    Brigadier General:
  • 6,966 Answers
A couple of things you could try:
  • if using Windows XP, pls update to SP2 or 3;
  • update the USB drivers from your laptop manufacturer's website (download & support page);
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 29, 2008
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
Mar 21, 2012 | Toshiba Satellite Pro 6000 Notebook
Hello is it possible to install a webcam without using a usb port please maybe a download ?? thankyou b.tunney
If your laptop doesn't have one built in, the only way to get one to work is with a USB port.
Apr 03, 2011 | Toshiba Satellite Pro L300 Notebook
I cannot connect my external hard drive through the sata port
Install the external hard drive into an USB hard drive adapter case. You can then connect this into the Toshiba's USB port. The Toshiba will see this as an external storage device.
Jan 08, 2011 | Toshiba Satellite Pro M300-S1002X Notebook
How do I connect a printer to my laptop
newer laptop only comes with USB ports. If you have an older printer that uses a parallel cable then it's time to get a new printer or get a parallel to USB printer cable.
Jun 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite pro 6100 usb not working
Try installing the usb driver or check if the usb ports is enable or disable if it is disabled plz enable it.To check this right click my computer click on properties,click on hardware devices,then click on usb to check it out.
Jun 28, 2009 | Toshiba Satellite Pro 6100 Notebook
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Problem with video
1.pls install codecs and uninstall all the unwanted software
2. use registry cleaner to clean your registry
3. delete all temp file from %temp% and prefetch
Mar 14, 2008 | Toshiba Satellite Pro 6100-102 PC Notebook
Usb ports on a toshiba satellite pro m15-S405
You can if you have good soldering skills. The welds are located on the opposite side of the motherboard. Just go to partstore.com or ebay to find a raw module to replace it. Otherwise you must replace the motherboard. Remember, heat the work not the solder, and use low watt if lots of smaller circuits are closeby.
Jan 06, 2008 | Toshiba Satellite Pro M15-S405 Notebook
TOSHIBA Satellite L30-10X Keyboard Set-up
Its just the problem with your USB drivers. Just update your drivers. You'll be fine
Apr 26, 2017 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
