Question about HP DeskJet 3745 Printer
Error problem when I give a print command there is window opens says "there was an error writing LPT1 for the printer HP D3745 the printer is not ready .........etc., how to solve this problem?
I found this problem raised because of improper installation of drivers. I have down loaded the drivers from HP site and got it rectified.
Posted on Aug 30, 2008
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
HP LJ P2035n print from Dos problem
win xp has dropped the printer driver
as it is no longer supported by Microsoft get it from the printers manufacturer web site
Jan 24, 2018 | HP "LaserJet P2035n Printer"
How to change the density of the printer HP LaserJet 5p
I'm afraid this won't be of much help to the original poster, who asked the question a year ago, but anyway - others may be looking for this too, just like I did...
To change the print density, a simple command must be sent to the printer. This is done in two steps:
  1. Create a file, containing the command
  2. Send it to the printer ("copy" it to the printer, in a DOS shell)
The command is:
where <ESC> represents the "Escape" character (character code 27). There are several ways to generate the Escape character (which cannot be directly entered in a text editor): E.g. substitute the character with any other, save the command and then replace the first character with 0x1b using a hex editor.
  • Open a DOS window
  • Enter:
    copy con density.txt <Enter>
  • Hold the <Alt> key
  • type 27 on the numeric keypad
  • Release the <Alt> key - the Esc. char. is shown as ^[
  • Type the rest of the command (e.g. %-12345X@PJL DEFAULT DENSITY=4) - adjust the density value to the one you actually want to set.
  • press <Enter> <ctrl-Z> <Enter> to write the file
When you have successfully created the command file, send it to the printer. In the DOS window, enter:
copy density.txt LPT1
(assuming that your printer is connected to LPT1)
That's it!
To verify that the density has actually been set, print a printer status page.
The printer remembers this setting, so this needs to be done only once.
Mar 31, 2009 | HP LaserJet 5p Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Need help installing the firmware for an HP LJ p3005n. I have the download, and the printer is locally connected *USB*
As per the instructions from HP for windows systems:
If the device is shared on the network, then the following command can be issued from a command prompt: copy /b FILENAME \\SHARENAME\PRINTERNAME
where FILENAME is the name of the .RFU file,SHARENAME is the name of the machine, from which the printer is being shared, and PRINTERNAME is the printer's share name.
If the device is attached locally, then the .RFU file can be sent directly to the printer with a COPY command from a command prompt or DOS window:
where FILENAME is the name of the .RFU file and PORTNAME is the name of the appropriate device port (such as LPT1).
The following can be set on the computer to help address a timeout message that may occur during an update:
From a command prompt or DOS window type the following command and press the enter key:
Mode lpt1:,,p
If the device is attached to a parallel port other than LPT1, then substitute the proper LPT port number in the MODE command. Once this command has been set the file can then be copied to the printer with the above mentioned COPY command.
NOTE: When the upgrade process has completed the LaserJet will reboot. Once the printer is back online, print a Configuration Page and verify that the new firmware has been installed.
Alkaline Water
Dec 05, 2008 | HP LaserJet P3005n Printer
Print not comming
my printer hp 2300 print only on page
Sep 17, 2008 | HP LaserJet 2300 Printer
System error in printer hp deskjet 3320
Normal 0 In XP go to Control Panel
Open System
Click the Advanced tab
Click Settings under Performance
Click the Data Execution Prevention tab
Make sure Turn on DEP for all programs is NOT checked, check Turn on DEP for essential Windows programs.
Apr 04, 2008 | HP DeskJet 3320 InkJet Printer
Dos Program in FoxPro
To answer the question, I need to k**w if your DOS session is running inside Windows. As this is the most likely scenario, I'll answer assuming that - the answer will be different for DOS only systems.
Has the faulty LPT1 port has actually been removed? If it has, why **t just alter the port number of LPT3 back to LPT1 ? This can be done with jumpers on an old style card, or from device manager inside Windows if plug and play. If **t, you can try the following:
1: If the printer is already installed in Windows on LPT3, skip to step 3:
2: Install the printer in Windows. If you don't have a suitable driver for it, you can use Generic/Text only driver.
3: Right click on the printer, go to sharing, and make the printer shareable. Use a share name of 11 or less characters and ** spaces - e.g. EPSONLX500
4: From the CMD prompt, type the command:
net use lpt1: \\%computername%\Sharename
net use lpt1: \\%computername%\EPSONLX500
**te that you do **t need to replace %computername% with your exact computer name - the machine will do it for you.
Finally, for others reading this, you can also use this technique to print from DOS to most "intelligent" USB printers (Hi end Laser, Dot Matrix etc). It probably won't work with "dumb" GDI printers or All-in-ones where Windows has to do all the work. If the printer supports PCL or ESCP printing languages, you are probably going to be OK.
Mar 10, 2008 | Office Equipment & Supplies
Printing,hp deskjet3420
Hi Malcom,
The HP3420 is connected to your PC through the USB port and not through the LPT1/parallel port.
You have to change the port setting. Go to Start, Printers, right click on HP3420, click on Properties, go to the Ports tab, check/select USB, OK.
Alternately, you may have to re-install the drivers for the HP3420 and allow the program to Search for the printer connection. Clicking on the button Stop Searching will auto install it again to LPT1.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Computers & Internet
HP DeskJet 3745 Printer Logo
57 people viewed this question
Ben Johnson
