Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Istalling windows Hi. I need help from somebody. My problem is that i have a new sata II 250gb hard disk in my computer. There is also a windows xp installed on my old 80gb hard disk.I wanted to install wiindows on the new one, so i plugged off the old one. But after restarting it was written: Disk boot failure insert system disk and press enter. So I installed windows xp onto new hard disk without plugging off the old one. Now when the system is loading, i can choose from 2 windows. But what can i do if i want to have only one, that one on the new. I again tried to plug off the old one after installation, but still written out? disk failure... Thanks for your help. Nice day for everybody!
    President:
  • 2,961 Answers
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Posted on Aug 29, 2008
I AM LOOKING FOR LATEST DRIVER DRIVERS FOR MAXTOR DiamondMax 21 SATA 250GB Hard DRIVE FOR WIN XP-PRO PC
The latest drivers and support would be available from the Seagate website. The Seatools utility is an excellent tool that is also available.
http://www.seagate.com/www/en-us/
I hope this helps.
Sep 03, 2011 | Seagate 250GB Maxtor DiamondMax Plus 21...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
2.5'' external fell down
Sorry, but if your hard disk fell down and now isn't regognized by the computer the most possible situation is that the disk is destroyed.
Stelios.
Feb 22, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
My system is not stable
Can be virus...hardware..or o/s issue
  1. Try taking unwanted files or prrgrams
  2. empty the temp folder
  3. Scan using latest anti virus
  4. Defragment
  5. if still same. Try formatting and re-installing the o/s..
  6. if still the same check replacing HDD ...or M/B
May 22, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
2 hard disks
Aug 29, 2008 | Microsoft Windows XP Professional With...
160gb samsung sata II
The PC is not seeing the Hard drive. check the jumper pin for the setting on the hard drive. If you have one HD then it should be set to master or cable select. Reboot and the cmos will see the HD. If not check the cables, and last check to see if the controller driver is installed for the motherboard. The controller is where the cable connects.
rmatheson@wowway.com
Aug 21, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Samsung 250GB HD250HJ SATA II.
Most likely if it makes sound then it is getting ready to crash, don't take a chance and remove your files and replace.
Jun 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Hey, congratulations on successfully installing the harddive.
Since its brand new, there is no volume in the disk (no partition and not formated)
To create a new volume and format the disk for the first time
on desktop, right click my computer icon, select manage from the menu, on the left side of the management window click on disk management
now on the right side, find your new harddrive, right click on it (its most likely the drive 1)
so right click on the 250gb hdd, create new volume, use NTFS default settings, and you may use quick format. normal format will take from 15 minutes to a hour or more.
with quick format the disk will be useable within seconds.
after this is complete you will see a new disk in my computer.
If you need more assistance let me know, I'm here to help
Also, remember to rate the solutions :-)
Apr 17, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
