Question about Video Game Consoles & Games
Trying to charge nintendo no light comes on no charge to the ds battery changed charger changed still not working
  • Anonymous Mar 14, 2009
    the charge light dose not come on when pluged in
Replace the battery" $9."
Posted on Dec 21, 2009
Get a new DS
Posted on Sep 21, 2008
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
I have been charging my ds for 5 hrs and red light still on
When you "Charge" the ds is the orange light on? if not buy a new charger
Nov 25, 2009 | Nintendo DS Lite Console
My nintendo ds wont charge and the light wont go red wen its charging i think i need a new battery
Before getting a new battery, make sure your charger isn't the thing that's broken. To do this, borrow a charger that works good from a friend and try charging your DS. If it doesn't work, than get a new battery.
Oct 09, 2009 | Nintendo Video Game Consoles & Games
Nintendo DS Battery charger
If its the charger that is it probably the charger its the battery. And a universal charger would work but try not to buy it off line if you can.
Jun 05, 2009 | Nintendo DS Lite
Nintendo DS does not turn on
Find a friend that has a DS and try using their battery and charger to troubleshoot your hardware. If your battery and charger work with another DS, then you may have a problem with your DS motherboard.
My assumption at this point is the battery.
Apr 10, 2009 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
DS Lite
You need a new battery. You can purchase one on ebay or at
Removing the battery and trying to play with the charger will not work either, you must have a working battery in the DS for it to come on or to be able to use the charger.
Mar 07, 2008 | Nintendo DS Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Ds light not coming on and charger not working
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Nov 28, 2007 | Nintendo DS Console
Need to know how to what's wrong & how to fix
for ur sons DS try to move it around to find a signal. for ur daughter's, trying doing the same first and if it doesnt work, buy a new charger if the new one doesnt work its the DS
Nov 02, 2007 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
201 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
