Question about Sharp Televison & Video
VHS tape stops playing after a few seconds - Sharp Televison & Video
    Brigadier General:
  • 6,966 Answers
Your concern indicates a probable fault in the take up spool (right side). Often this would be only a belt that requires replacement. In some instances, it could be the clutch under the "take-up" spool. You could try exercising the tapes (forward/rewind) before playing as in some occasion, the tape may be stuck/adhering to one another. Other than the last possibility, the unit has to be opened up and work be done inside. Should you be uncomfortable on a DIY (do-it-yourself) perhaps your best be would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 29, 2008
3 Suggested Answers
  • 308 Answers
SOURCE: Hitachi DV-PF33U DVD Player / VCR Combo
It sounds like the sensor to tell the microcontroller that the tape is moving is not working. If that is so, the VCR would probably do the same thing in FF or Rewind. If you end up taking this unit into a repair shop, have them check the DVD's software version (it should be 1.250) If below that number, have them upgrade that as well. You can check the version yourself by pressing 1,2,3,4 and then "display" on the remote while the unit is on and no disc in DVD. After noting the version, just hit "power" on the remote to exit this mode.
Posted on Jan 01, 2007
Benimur
  • 6966 Answers
SOURCE: vhs won't work
Hi, I recently replied to a similar posting/problem. Pls refer to this link > http://www.fixya.com/support/t210313-jvc_hr_s9700ek Good luck and kind regards.
Posted on Oct 05, 2007
After a long period of non-use,of my VCR, I recently tried to play a new VHS tape. It loaded properly, but refused to play it.
Could be the belts have become too old for the unit to function. you could try to take the unit apart to clean them.
Mar 25, 2015 | JVC Hr-a591u 4 Head S-vhs Hi-fi Stereo Vcr...
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Stuck vhs in vcr
check the tip in my profile
May 31, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
How can I get VHS tapes to play?
try to run a vhs cleaner thru it and it should help alot
Jul 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
My vcr won't play.
Sounds like a bad belt or the tape isnt loading into case correcly bad rubber idler assy.
Oct 23, 2008 | Quasar VHQ400 VHS VCR
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Televison & Video Logo
381 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
