As per the specs on this site:
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5570/Aspire5570sp2.shtml
It does have a microphone.
You should be able to turn it on by going into your sound options :
Down in the lower right-hand corner you should see your volume control icon. Double click on that and it will bring up your volume control panel. Your microphone control should be listed here. Just make sure to uncheck the mute box and turn it up.
You may have to go to "options" and check "microphone" to get it to show up.
You may also need to go into the sound options (Start->Control Panel->Sounds and Audio Devices) to enable the correct recording device. Once you're in this window select the Audio tab and make sure your microphone is selected as the default recording device.
That should do it.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
