Question about Sanyo PLC-XU47 Multimedia Projector
How do i change a bulb please
Just need to access bulb inside
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
PLC-XU47
See page 48:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 29, 2008
How to change bulb in BL3100
I can locate no information on your particular machine--even whether it is a serger or sewing machine.
However, sometimes the bulbs are accessible from below where the bulb is located. In some cases, rubber fingers, rubber garden gloves, or a tool will help provide the grip needed to grasp the bulb to remove it.
Jul 28, 2016 | Sewing Machines
How to change tail light
If there's no screw heads outside, it only means they are accessable from inside the trunk by removing the carpeted panels that just pull out. Don't pull too hard and break or bend them. The bulb is inside a housing you have to twist and pull to get to the bulb. Remove the bulbs and put the new ones in.
Aug 06, 2014 | Ford Fusion Cars & Trucks
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
How to change bulbs on Dimplex HTN 20
If you have a compact fireplace in a cabinet mantle, you will need to remove the front Plexiglas and frame from the front of the firebox. Remove the logs, then the 1- piece ember bed (it just lifts out). This will give you access to the light bulbs.
If you what looks like an old wood stove, you access then from the rear of the unit. Remove the bottom access panel by unscrewing the 4 screws that hold it in place. You can then reach the light bulbs to change them.
In both cases, the replacement bulbs are small base chandelier bulbs.
Hope this helps to solve your problem.
Mar 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
Jan 07, 2010 | Frigidaire FMV156DC Microwave Oven
How do I replace a tail light
Not sure if you mean the whole tail light assembly or only the bulb. For either one on that vehicle it should be the same process, more than likely you will have to remove a few screws inside the rear hatch which should allow the tail light assembly to be pulled out. The bulb connector will have a clip or will need turned a certain way to pull the bulb/connecter out of the assembly. Replace the burnt bulb and reassemble. Since I haven't seen the vehicle, there is a chance that is like some cars and the access to change a bulb is accessed from inside the vehicle inside the rear compartments.
Oct 23, 2009 | 2000 Toyota Sienna
How to change a headlight light bulb on toyota prius 2006?
they are usually changed from inside the engine compartment. you should be able to gain access to the bulb behind each headlight bazel. the socket often has to be turned to remove it. be careful not to touch the new bulb with your fingers as that will shorten it's lifespan. you may have to remove the battery if the burnt out bulb is on that side.
Robert
Please take a moment to rate this solution... thanks
Apr 15, 2009 | 1999 Ford Taurus
How do i change my rear indicator bulb in my 04 beetle?
open rear hatch and look strait down on inside boot well. the plastic trim has access holes that pop out on either side just behind the lights. pop out the access cover on the side with burnt bulb, then reach inside that hole and you will fins a large plastic "wingnut", unscrew it<careful not to drop it or you'll have to take the whole boot apart to retrieve it> after removing wingnut carefully pop out lens from outside , replace bulb and reinstall after testing
Mar 19, 2009 | 2000 Volkswagen Beetle
Need to change bulb inside Amana radarange RR1220
There is an access / cover panel on the back of the oven.
It's shown in the exploded view here.
Please unplug the oven from the wall first.
Then use a 1/4" nut driver or socket to remove the screw in the end of the lamp cover.
The bulb is behind the cover, and should be readily available at grocery stores, home improvement centers, hardware stores and big box stores like Wal-Mart.
Dec 01, 2008 | Amana Radarange Microwave Oven
Jenn-air microwave light bulb
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Sanyo PLC-XU47 Multimedia Projector Logo
99 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
