Unable to connect to internet, needs wpa network key, help
    President:
  • 2,961 Answers
These are a mixture of numbers and letters which you enter yourself because security is enabled, its not something we can give you its the code within the routers menu, it will be visible in there in the security settings.
if you are trying to connect to somebody elses connection, then without permission it is ilegal and obviously you will not be able to get the numbers for connection
Posted on Aug 29, 2008
Sony SMP N200 Network Media Player - unable to connect to home wireless network
You may need to enter the SSID in the wireless configuration in the Sony.
Check the Netgear wireless setting ie. the SSID, WPA or WPA2 encryption key, then apply these settings to the Sony wireless card settings.
Mar 20, 2012 | Computers & Internet
Trying to connect to the internet through Wii but getting error messgae # 51330
Error Code: 51330
Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings.
WEP AND WPA Security keys are case sensitive.
Aug 28, 2011 | Computers & Internet
Unable to find WEP Key
The WEP encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
I recommend you use WPA or WPA2 encryption, it is much stronger than WEP.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 04, 2011 | Belkin F5D7234-4 Router
Suddenly today after working for a couple of years all the lights are on solid and my wireless laptops can not find the router
To connect to your wireless network using Vista's WLAN Autoconfig, follow these steps:
Step 1:
Right-click this icon 5449-001.png at the bottom-right corner of the screen and select Connect to a network.
Step 2:
Select your Wireless Network Name or SSID then click Connect.
NOTE:
If the wireless network name or your SSID is not listed, the SSID Broadcast on the router might be disabled. For instructions on how to connect to the wireless network with the SSID broadcast being disabled, click here.
If the computer is not detecting any signal or is not seeing any wireless network, change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless connection even if the wireless security is disabled on your router. If you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing Unable to connect to a wireless network using WEP in Windows Vista Windows Vista Articles Listing Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router Setting-Up the Wireless Settings on a Router Assigning a Static IP Address on a Wired Computer
Nov 06, 2010 | Linksys WRT300N Wireless Router
Looking to connect awireless laptop printer and need the WEP or WPA key for the wireless network
WEP or WPA Key is the password for your wireless network.. it's the same password you used to connect your laptop to the wireless.. if yo forgot what it is, you might need to contact the manufacturer of the router or your internet service provider to reconfigure or re-setup your wireless network.. hope this helps a bit.
Sep 08, 2010 | Office Equipment & Supplies
My son can't connect to x box live, it keeps asking for the wpa key, what is this and where do I get it from?
Your WPA key is simply put, the password that protects your internet. (Wi-Fi Protected Access). I'm assuming you have a wireless internet and that is how your son is connecting to Xbox Live? (Unless he is mistakenly connecting to another wireless network other than your own.)
Someone in your household should know what the WPA key is, because it was the password set to protect your internet. (Most likely done so on a PC or laptop.)
So here are my suggestions:
1. Make sure your son is connecting to the right wirless network on his Xbox. You can do this by going to Settings --> System Settings --> Network Settings --> Configure Network --> Clicking A once you get to that Menu, and then scanning for Networks. Chances are you will get a few results. In order to connect to Xbox Live, you have to chose your wireless network.
2. If no one in your household knows the WPA key, I would suggest contacting who ever set up your internet, or another option would be to connect to Xbox Live directly, using the modem cable. (You would have gotten this when you originally bought the Xbox.) This can get pretty complicated however, so I would suggest trying to figure out the WPA key.
I hope I was of some help, feel free to contact me if you're still confused.
Jan 31, 2010 | Microsoft Video Game Consoles & Games
Need wpa key for xbox live
WPA key is your Wireless router key for internet access.
To connect your console to wireless internet and go to Xbox Live you must enter WPA key for your wireless router.
It`s a same key than you use to connect your Notebook, cellular phone, etc. to your home network.
Dec 19, 2009 | Microsoft Xbox 360 Console
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
CAN'T CONNECT TO WIRELESS ROUTER WITH LAPTOP.
Temporarily disable all security on the router AND your laptop wireless card and try again to test connectivity.
The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
This is caused by setting the encryption to WPA-RADIUS instead of WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it should30924e8.jpg work.
Also check to make sure that IEEE 802.1x authentication on the wireless network properties Authentication tab is disabled.
Jan 04, 2009 | Linksys WRT160N Wireless Router
Connecting to network
[QUOTE]The exact error message should be:
Google shows 37 hits with this exact phrase.
will work.[/quote]
Jan 16, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
