Question about Sony Cyber-shot DSC-S600 Digital Camera
Question Yes the shutter does open, but the lense physically doesn't come out although I hear that it tries. When I turn off the camera the shutter doesn't always shut... How to I re-initiate the camera?? Thank you
  • jilott Aug 29, 2008
    Thank you. I have spoken directly with SONY this morning, and becuae they haven't registered this as a known fault and my camera is out of warranty they wanted to charge me an additional £114 for the repair!!!
    Problem Solver:
  • 4 Answers
First, i suggest you try this. Remove batteries then press and hold power button for 15 seconds. Wait a further 1 minute then reinsert batteries and try again.
If no good, try this. If you can get to the MENU mode (in stored pics), scroll right to SETUP, press centre button to OK it. Scroll down to SETUP1. Scroll right, then down to initialize which will be lit yellow. Then scroll right and scroll up when ok will be lit yellow then press centre button to OK it. This will return camera to factory defaults including set up language.
Good luck !
Posted on Aug 29, 2008
My nikon d3100 is saying error press shutter release button again and it dont do nything.. it also has a dark blurry film when i look through the lense ?
Hey Julie,
We'll solve your problem in a moment.
Step 1,
First, I need you to look through the viewfinder, and press the shutter release button, half-way, and notice the difference. Don't let go, till you hear a beep sound. The blurriness that you see will clear automatically.
If you hear no noise, and the blurriness doesn't go, try this.
Step 2,
On the lens, there will be a tiny button. It'll have A-M on it. Switch it to 'A', if not already on it.
Once you do that, try step one again. Now, you'll be able to overcome your problem.
Toodles,
Rebel!
Sep 18, 2011 | Nikon D3100 Digital Camera
Shutter wont open or close
Hi seems to be a mechanical problem.
Feb 20, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
I have a hasselblad 503cx. when i hit the shutter button, the back part of the lens opens (where the film is) but the lens shutter is closed. when i let go, the lens opens and the back closes.
The proper order of exposure should be:
Curtain opens/Lense stops down (unless wide open)
Lense shutter closes
When releasing button, curtain closes
When winding, lense shutter opens
If this isn't what's happening, something is wrong. There is only a simple mechanical screw connection between body and lense, so it'd have to be an issue with the gears in the body.
May 21, 2011 | Hasselblad 503CX Medium Format Camera
When i turn on my camera the lense extends but you can not see thru neither the lense or the remote screen. please help
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 15, 2010 | Canon PowerShot S2 IS Digital Camera
Nikon 18-55mm AF-S/ VR lense shudder?
I believe you're hearing the VR in the lens adjusting. Try turning the VR off and see if you hear the sound. If not, then you have a normal operating lens.
Sep 01, 2009 | Nikon D5000 Digital Camera
Lens will not extend
Hi:
You need to clean around the lense first. Blow high pressure air spray and get the most sand out of the lense you possibly can.
If it did not open 100%, try to pull it out NOT too hard. If the lese goes up and down and turns you should follow the lense while pulling it out.
When it is 100% out, (the way normally opens) Clean around the lense more.
Turn you camera on and off a few times. It should be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 20, 2009 | Konica Minolta DiMAGE G500 Digital Camera
Camera will shut off then the shutter will close
Yes it could. It is possible a small dirt get on the side of the lense and it prevents the lense to close all the way in. Clean it up and while turning the camera off, push the lense in. Not too hard. You might have to repeat the step a few times. Do not drop your camera, if you did make sure you clean the sides of the popped off lense. If they did not help, some mechanical part of the lense is shifted or broken.
Good Luck
Jun 08, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Feb 19, 2008 | Photography
HELP! dropped camera, lens won't go back in, shutter won't close
Tapp the lense GENTLY in the opposite direction of the misalignment
Nov 25, 2007 | Kodak EasyShare DX6490 Digital Camera
Digimax i6 pmp SHUTTER problems!!!
Congratulations on fixing the problem! However I just wanted to let you and everyone else who reads this solution know that the part which failed on your camera is not actually the shutter. The shutter is deep inside the lens assembly right next to the image sensor. What you were dealing with was simply a protective cover for the lens. David Millier Advance Camera Repair
Feb 03, 2007 | Samsung Digimax i6 PMP Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
61 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
