IS this a 175 psi unit. What was the safety valve psi that was replaced. I recommend removing the heads and checking the valves. Suspect you will find one of them bad.If safety is past the hp head remove and check hp valves first. If safety is after lp head check it first. I have seen and lp valve break and pieces carry over to the hp side. So if lp valve bad you may want to inspect the hp side also. Good luck!
