posted by Guest on Sep 11, 2005
If have a warning message "CARD ERROR" in the LCD Display. what shuold I do?
1 Other User Has The Same Problem
Comment by ickylicky, posted on Jan 01, 2008
I turn on camera, get a beeping sound, says to "format card" Yes or No. Hit a button and then it says "card error"..... WHAT DO I DO????
Toshiba pdrm25
Solution #1
posted on Dec 18, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Download "GetData Recover My Photos" and get the photos out of the damn card! Then throw it away!
PS. SD (Secure Digital) cards are enhanced MMC (Multi Media Cards) and they are completely identical except for additional pins and card lock write protection on SD cards.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 11, 2005
Adig - usenet poster
Rank:
Wiz
Rating: 82%, 18 votes
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following:
Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary.
Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position.
If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased.
Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Suggest a new solution for this problem
Post a New problem for Toshiba PDR-M25 Digital Camera
Email this problem
Email this problem
Can you Help with these Digital Cameras problems?
Top LCD display not working
The top black LCD display that... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
