Question about NAD C370 2-Channel Amplifier
NAD C370 Right channel distortion
Hi, bought this amp as new old stock last week. Worked fine for a few days. After leaving switched on unused for 3 or 4 days I noticed the protection light was red. Powered off to reset. Protection now remains off but the right channel is distortred and lower volume than left. Treble not too bad but bass sounds like the speaker woofer is knackered ( it's not). Thanks for your help.
  • etchellsrace Sep 30, 2008
    I have the same problem except in my left channel. My NAD C370 worked fine till then. Any ideas about finding a local repair shop in San Antonio, TX?
  • NAD Master
  • 5,259 Answers
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Posted on Feb 16, 2009
Working on furnace. igniter not working even after replacing.
Check flame sensor , check hoses to pressure switch not split etc
Oct 24, 2015 | Goodman Heating & Cooling
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
My old ceiling fan capacitor has A B C D on the back , the new capacitor has 1 2 3 4, how do I connect the new one????
I just changed out an old ADCB (172-90-001 / 1-81-M) fan speed switch with a L123 3 speed switch (Westinghouse 77286). My fan was only 2 speed but the 3 speed switch was all the Home Depot had in stock. So I knew I would have OFF occurring twice in the pull sequence. Its an old Hunter fan that came with the house.
A-Unused
B-Went to 1 (Blue Wire)
C-Went to 2 (Red Wire)
D-Went to L (Black Wire)
I originally put B (the Blue Wire) into spot 3, leaving 1 unused. But that made the pull order go OFF-OFF-LOW-HIGH.
So moving the Blue Wire to the 1 slot resulted in OFF-HIGH-LOW-OFF
Hope this helps!
Apr 01, 2012 | Dryers
I bought the amp a few weeks ago and it worked perfectly for a couple of days and then for some reason the controlls just froze. the tap tempo light went out and the channel control light stayed the same...
Exercise your warranty IMMEDIATELY since you just bought it! If you bought this used, you LIKELY bought someone else's problem. The problem is likely in the digital effects area... probably a bad cable contact... but if under warranty DO NOT mess with it... return it for replacement or repair.
Sep 09, 2011 | Marshall Amplification Marshall MG30FX...
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Intrepid Does not Shift & Speedometer Inoperative
Check the output sensor on the transmission,
With out a speedometer the transmission does not know how fast you are going or when it should shift
Dec 01, 2009 | 2000 Dodge Intrepid
Old Jacuzzi Vectra (86), not cycling!
Keep giving it a few kicks! When that happens to motors it usually means that it is on its way out, I'd milk it for as long as possible but start thinking about a new pump and motor.
Aug 03, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
After leaving my Sony DSC-T2 camera unused for only a couple of days the battery was flat. I recharged it fully but again it only lasted a day or two. I assumed the battery was dead and I purchased a new...
If the troubleshooting section in the back of the user guide doesn't help, I sugget getting in touch with Sony and asking them if it's normal, the only thing I can suggest in the meantime, is taking the battery out while it's not in use, or recharge it a few hours before you're due to use it. Phones get like it after a few years and with technology advancing the way it is these days, you'd expect a battery life lasting longer than a week, not a day.
Things to consider:
1. When it's off, is it off or left on standby?
2. Where did you buy both the camera and batteries from?
3. When you charge it up, do you charge it up with a half charged battery or a totally dead battery?
Jul 20, 2009 | Sony Cyber-shot DSC-T2 Digital Camera
Unusable signal
we had that problem last week.i bought a new remote control and it worked fine.
Jan 01, 2009 | RCA L37WD12 37 in. LCD HDTV
NAD C370 2-Channel Amplifier Logo
683 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
