Question about Refrigerators
Refrigerator brief loud knock when compressor shuts off
I have finally traced a strange noise to my 11 year old Kitchenaid KTRS21KDAL02 refrigerator. The noise is very brief -not over a second. It is a fairly loud knock like sound with a bit of rattle following, and it happens just as the compressor turns off. It has been going on some time, but I just traced it to the refrigerator. I pulled the metal cover for the back bottom section where the compressor is located. The compressor seems to be well attached with 4 bolts going through rubber mounts to the bottom panel of the refrigerator. I could not find anything that seemed to be knocking together when pressed by hand. This does not happen every time the compressor turns off, and when it does not happen you just hear the normal relay click. There is a fiberglass pad or something of the sort stuffed between the top of the compressor and the top of the metal compartment in which the compressor and other components are in. If this is something serious and the refrigerator is about to fail, I would just replace it. However if it is not likely to be serious I can live with the noise.
  • jralbert Apr 15, 2009
    Same problem as original post describes
  • Anonymous Mar 28, 2014
    WHAT COULD BE THE PROBLEM
  • 1,543 Answers
The compressor you see is actually the outer shell, inside of which is a refrigerant pump (ie:compressor) which is on internal support springs. When the unit turns off, the momentum of the internal parts can sometimes knock against the outside of the compressor case. The only "fix" would be a new compressor. In the real world, the fix is to live with it. It's generally not an indication of immenent compressor failure and most likely will run many more years with no problem. Note: if you put your hand on most compressors (even new unused ones) and give them a shake, you will hear that noise.
Posted on Aug 29, 2008
    President:
  • 949 Answers
The very first thing to check is the mounting assembly. Most are mounted on dampeners, or springs, they are so the motor can take the shock of starting and turning off. If you check the mounting assembly and do not notice any excessive movement in the motor between it and the mount, then what Carl said would be the problem.
Posted on Apr 02, 2012
My KSRP25FNSS makes a strange knocking noise at each compressor shut down and sometimes during running. The noise is always a series of 5 knocks, very loud, in quick succession that telegraphs though
By you discription above it sounds like one of the three spring the supports the compressor pump has failed or broke. Now the only fix is to have the compressor replaced, but if the unit is still cooling, currently its a noise problem only. I hope this helps you. If this is still under a warranty, ask for it to be checked as if in warranty it needs to be replaced. Good Luck
Jan 04, 2015 | KitchenAid KSRP25FNSS Side by Side...
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
We have an 11 year old fisher-paykel fridge .For past 6 months several times a day it makes a loud knocking noise
If this noise happens when the compressor turns on and shuts off it is called a compressor knock. All the internal workings of the compressor are supported by springs, over time the springs wear out and become weak. When the compressor stops or starts the tourq causes the internal parts to hit aginst the casing of the compressor. Sounds like a clunk clunk clunk noise. If you can deal with the noise do not go out and replace the compressor cause it will work just fine like that.
Sep 01, 2011 | Refrigerators
Kitchenaid refrigerator / freezer knocking noise
Hmmm. Makes sure it is not the fan inside the freezer. The compressor is not capable of loud noise since it is sealed and sits on rubber mount. The knocking might be due to the fan blade hitting ice build up. You should not see any frost in a freezer. If there is frost, you can defrost completely then set the fridge to a lower setting.
Feb 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
When the compressor (thermostat?) shuts off, it makes a very loud noise. Freezer and refrigerated area are keeping things cold just fine. Refrigerator is 12 years old.
The compressor has 3 or 4 internal motor support springs . Over time , one can rust , due to the contaminates in the refrigerant system . One of them can break free , which will not cause any damage , other than a clunk , when the compressor cuts off . You can still have many years of correct cooling , only the noise will be present .
Nov 19, 2009 | Refrigerators
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
I have 10 year old Roper refrigerator. Frig is a
the thump is your compressor shutting off.you can try changing the rubber grommets but most likely your compressor is just going to be loud until it finally dies.
Mar 05, 2009 | Refrigerators
Refrigerator compressor makes a loud rumble when it shuts down.
Mack sure it's level. some times that will cause noise. if it's still cooling, don't worry.
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Refrigerator making loud noise
Does the sound occur when the compressor is starting or shutting down? and only lasts for a couple of seconds? I had one do the exact same thing. Sometimes it would also wake me up at night. If so, I'm afraid he is right. On the bright side, it worked fine for years. I gave it to a girlfriend when I purchased a bigger one and it is still working today. The only thing you can do is change the compressor, which is probably not $$ practical.
Nov 05, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
4,910 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
